Converting a file from .RMVB which is 310 MB to MP 4 using Aimesoft Video Converter, and the size of the converted MP 4 file is 680.0 MB?
Doing this because ConvertXtoDVD does not take .RMVB file,kinda an irony,since the program is "suppose" to take in any format......LOL
				Results 1 to 10 of 10
	Short answer: things are much more complicated than you thinkOriginally Posted by niteghost
 Long answer: you still have some tons of reading to do, and you could start at https://www.videohelp.com/glossary
	Are you sure convertxtodvd doesn't support rmvb? Tried choose open all files?
 Or try avstodvd and import the rmvb and make a dvd.
	No need to LOL - there is NO program that takes in EVERY format. Why would you be fooled into thinking there was?
 Simple answer about the 1st part is the 1st formula of media files: FILESIZE = BITRATE * RUNNING TIME
 Your source file is 310MB (aka 2480Mb). Let's pretend it's running time is 1 hour (aka 3600 sec). 2480 = X * 3600. Solving for X = 2480/3600=0.6888Mbps.
 Assuming your same title has the same running time in the 2nd/target portion (it should), 680MB (aka 5440Mb) works out to 5440/3600 = 1.51Mbps.
 Different format, different efficiency, (likely) different settings, different bitrate=different filesize. No surprise at all.
 ScottLast edited by Cornucopia; 24th Apr 2015 at 17:40.
	In simple terms: every time you want to convert a compressed video the originally compressed video is uncompressed first and then this uncompressed source is compressed again.
 Unfortunately current codec technology is generally not smart enough to reuse previously encoded information in new transcoded material, they usually completely start from scratch (e.g. 100% decompressed courses).
 Of course that's totally inefficient but that is the state of the art in compression world. Present day codecs are so inflexible that you cannot even remove a few frames or crop a video without a complete transcode. Luckily some advanced engineers start thinking about things like using meta data to provide more flexibility in editing but for instance the simple concept of abstracting video dimensions, orientation, levels and up to a certain extent color spaces in the meta data is way above the state of present day codec development.
	Yeah,unfortunately where I download the .RMVB file,ConvertXtoDVD does not take it, that is why the added "xtra" work and I have to Re-Compress the file to fit 7 episodes on a DVD-5
	@newpball,
 Again, not true. Example: Restream & DVDShrink have been able to do MPEG2 transcoding (using compressed transform passthrough, aka NOT FULLY DECODING) for ~14 years.
 There ARE plenty of I frame codecs that allow you to remove frames (without re-encoding).
 There are codecs that allow you to crop.
 There are other codecs that have other types of flexibility.
 What you don't seem to understand is: YOU CAN'T HAVE IT ALL. And certainly, not even MOST, without some other compromise. Choice of codec is often based on prioritizing your compromises in line with your ultimate intentions. The tripartite constraint and the adage "you can't have your cake and eat it too" is quite common in the information field. Try to grow up and learn something. Unfortunately, until you are illuminated, my guess is you will continue to impotently point blame elsewhere (such as engineers).
	niteghost, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules: Thanks,Try to choose a subject that describes your topic.
 Please do not use topic subjects like Help me!!! or Problems.
 Moderator redwudz
  How to convert SubExtractor's output .bin file to .srt file?By EmmB in forum SubtitleReplies: 2Last Post: 14th Jun 2014, 22:36
  Can't convert an AVI file to a readable H.264 file with Adobe Media EncoderBy JeffTchaderjian in forum Video ConversionReplies: 0Last Post: 1st Jun 2013, 10:26
  convert .xls file to Subtitle Workshop import fileBy longlostname in forum SubtitleReplies: 1Last Post: 7th Oct 2012, 19:13
  How do you convert HD 720p MKV file to MP4 HD file without losing quality?By SoccerLover in forum Video ConversionReplies: 18Last Post: 4th Nov 2010, 09:30
  How to convert the 1gb VOB file to 80Mb AVI file ?By zohaibshaikh in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 07:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
 Quote Visit Homepage
				Visit Homepage
