Hi,
Im using subtitle edit to convert this subtitles in xml:
http://bngnwww.b-ch.com/caption/35470338/1685/953686131674292/1362883900.xml?cashPath=1429887605621
to ass but I cant. I get a lot of broken lines. Maybe im doing something wrong? Any suggestions please?
Thank you.
Results 1 to 13 of 13
I don't know which language you want?
Anyway I tried the first (Trad Chinese) and I think it's okay?
For the English there's a lots a double line breaks. Open it. Use Tools -> Fix common errors. Save as SRT. This will remove the double line breaks. Open the .srt. Save as .ass. -
Thank you. Actually i need the spanish latin one. However I would appreciate if you tell me how to do it so i can learn to do it myself.
Edit out the spanish part in the XML file with Notepad or the like. Then as for english.
Can you please tell me your method? Because thats the one im using but I couldnt get the result i want.
I'll try.
I marked the file you upload with Ctrl+A and pasted it into notepad, edited out the first line and saved it with Unicode encoding.
To find the spanish latin I searched the xml tag "lang=" and cut out the other languages and saved as spanish.txt
This I opened in Subtitle Edit. Used "Tools -> Fix common errors" and saved as .srt
This I opened in SE and saved as .ass -
This one
This XML file does not appear to have any style information associated with it. The document tree is shown below.
You cut out all parts from "<div xml:lang=" to the ending "</div>" for all other languages except Spanish Latin -
Yes, my text file starts exactly from: <div xml:lang="Spanish Latin">
and ends with:
to vez el Cosmo?
</p>
</div>
I opened with the program and applied fix common errors with all the defaults. However the file is not as clean as yours.
Convert srt or ass subtitles to xml
By D Archangel in forum SubtitleReplies: 6Last Post: 19th Jun 2014, 02:16 -
How to automate fcp to xml conversion
By jeromedroz in forum MacReplies: 1Last Post: 18th Jun 2013, 12:11 -
Conversion of video to mpeg 7 xml
By Rimaz in forum ProgrammingReplies: 2Last Post: 2nd Apr 2012, 14:29 -
assToTtxt: basic subtitle conversion from .ass to .ttxt
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 25th Jan 2012, 12:00 -
CLI to XML
By eon_designs in forum Video ConversionReplies: 1Last Post: 29th Apr 2010, 10:50
