From GSpot 2.70a (Is there something newer to replace this program?)
isom: MP4 Base Media v1 [IS0 14496-12:2003]
- iso2: MP4 Base Media v2 [ISO 14496-12:2005]
- avc1: MP4 Base w/ AVC ext [ISO 14496-12:2005]
- mp41: MP4 v1 [ISO 14496-1:ch13]
Recommended Display Size: 1920 x 1080
mp4a: MPEG-4 AAC LC
44100Hz 197 kb/s tot , stereo (2/0)
Frame rate is 23.976
The videos play fine in Windows Media Player and VLC in Windows 7 but in Windows Media Player, VLC, Media Player Classic and Power DVD in Windows XP the audio lags behind the video, getting progressively farther out of synch.
How can I fix this so they'll play correctly no matter what operating system and player software is used? I don't want to have to re-encode these large files.
I have CCCP installed on Win7 and XP. Need to check if it's the latest CCCP on XP, that box is at a friend's place, connected to an old rear projection TV that only does 480p or 1080i and we can't get the PC to output 1080i.
So he puts up with fat and blurry pixels.
Code:General Complete name : C:\path to the file\video.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 819 MiB Duration : 27mn 5s Overall bit rate mode : Variable Overall bit rate : 4 229 Kbps Writing application : Lavf54.63.104 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 27mn 5s Bit rate : 4 096 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.082 Stream size : 780 MiB (95%) Writing library : x264 core 132 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=cbr / mbtree=1 / bitrate=4096 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=4096 / vbv_bufsize=4096 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 27mn 5s Duration_LastFrame : -5ms Bit rate mode : Variable Bit rate : 197 Kbps Maximum bit rate : 4 096 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 38.1 MiB (5%) Language : English
Get rid of the codec packs.
CCCP
NOTE! If you install all the included codecs/decoders you might get problem with other video software on your computer.
KLite
MPCStar
XCodec Pack
NOTE! If you install all the included codecs/decoders you might get problem with other video software on your computer. -
With CCCP removed, what needs to be installed to play an MP4 with AAC audio and AVC video? XP has no native support for that, and it'll also need to be able to play Xvid/Divx, anything that can be in an MKV or AVI, all varieties of MPEG etc - in other words anything and everything there is with video and audio.
I've been searching some more and progressive AAC audio lag is a very common problem across many operating systems and hardware platforms. I see many asking how to fix it on Android, iOS, and OS X. The second model of media player device Western Digital made had it bad, after the first version was perfect, and it looks like WD never debugged the firmware to fix it.
Looks as if there's something that software has to do *just right* to keep the audio in sync, yet for years time and time again people keep doing it wrong with the software/firmware.Last edited by bizzybody; 26th Apr 2015 at 18:04.
+1 for ffdshow.
If all you need to do is play media files, you could use MPCHC or MPCBE (with internal decoders/splitter enabled) and probably be done.
Otherwise, you need a media splitter as well; it's almost certain your codec pack included one. If you see a folder in programs named Elecard or Haali after uninstalling your codec pack, delete it manually. (A corrupt splitter install can cause your sync problem, and the presence of the corrupt folder can also bugger a good re-install).
Then do a clean install of Haali Media Splitter.Pull! Bang! Darn! -
For testing, I'd try the portable version of MPC-HC. It's self contained and shouldn't use any external codecs so you can test without uninstalling anything.
I'd also try opening a problem MP4 with MKVMergeGUI and remuxing as an MKV, then testing the audio sync for the MKV. I've found MP4 a bit problematic in the past, although admittedly that's been related to the splitter used by the player not respecting any audio delay specified in the MP4 file and shouldn't be a problem these days. Still changing formats for testing can't hurt.
If you're still having a sync problem, and it's still a problem with multiple players, maybe it's a hardware issue. It shouldn't be an XP problem as such.
If the PC's old and the CPU is running at around 100% to decode 1080p (assuming the video card isn't decoding) that might cause sync problems.
conversion TS to Mp4 with Avisynth/FFMpeg is out of synch
By Chris33 in forum Video ConversionReplies: 14Last Post: 27th Aug 2013, 01:49 -
MKV to MP4 conversion software for WIN7/8? (without loss in audioquality)
By alexeliasson in forum Video ConversionReplies: 2Last Post: 15th Nov 2012, 12:01 -
Help with MP4 in Virtual Dub on Win7
By wynden in forum EditingReplies: 2Last Post: 27th Apr 2012, 02:28 -
Audio-Video Capture on Win7 Home Premium Aspire 5334 Laptop
By vaudkid in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2011, 23:26 -
Win7 Live Movie Maker degrade audio
By NautTboy in forum EditingReplies: 2Last Post: 20th May 2010, 03:08
