Ok. I can't install "mpeg2enc, mencoder e mplayer" because I don't use an admin password and as I click on the install button the answer is
"WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:Sorry, try again.
Password:
sudo: 1 incorrect password attempt"
So: no way to install ffmpegX?
can you help me?
thanks
The installation requires that the app uses the sudo command. This in turn requires a non-blank admin password [1].
You need to be loggin in on a user account with admin privileges for this installation.
If your admin password is blank (sometimes referred to as “no password”), you must first assign a password to your user account in System Preferences > Users & Groups (or: Accounts).
If you must, you may set the user password back to blank after installation of ffmpegX, as that is the only time that ffmpegX needs it to be set.
ffmpegx.com installation
By a.fritz in forum Video ConversionReplies: 1Last Post: 16th Jan 2011, 23:38 -
Installation of ffmpegX on os X.6 : error message
By Gruntosaure in forum ffmpegX general discussionReplies: 5Last Post: 22nd Dec 2010, 18:54 -
Guide How to make a dvd with selectable subtitles on Mac OSX with ffmpegX
By ulmis in forum ffmpegX general discussionReplies: 29Last Post: 24th Nov 2010, 11:54 -
Installation of ffmpegx
By Docdawh? in forum ffmpegX general discussionReplies: 12Last Post: 19th Nov 2010, 00:13 -
Installation Failure on Mac 10.6 ffmpegX 0.0.9y
By metalhaze in forum ffmpegX general discussionReplies: 5Last Post: 20th Oct 2010, 11:41
