    Mar 2009
    I'm looking for help with the html5 video player at www.video.js.com.
    I have several players on a web page and the issue that I'm trying to figure out now is why, in Safari, the play buttons look like this (see attached image)?
    I look forward to any comments/insight you might have.
    Can you set any size for the button images? How does your html and javascript code look like?
    And I recommend stackoverflow for html/javascript issues. See https://github.com/videojs/video.js/wiki/Support
    Mar 2009
    Thanks for your reply.
    I have these in the header:
    <!--[if lt IE 9]>
    <script src="http://html5shim.googlecode.com/svn/trunk/html5.js"></script>
    <![endif]-->
    <script type="text/javascript">
    document.createElement('video');document.createEle ment('audio');document.createElement('track');
    </script>
    <link href="http://www....com/video-js-4.12.5/video-js/video-js.css" rel="stylesheet">
    <script src="http://www....com/video-js-4.12.5/video-js/video.js"></script>
    <script>videojs.options.flash.swf = "http://www....com/video-js-4.12.5/video-js/video-js.swf"</script>
    <script>
    videojs("_1200k.mp4", {}, function() {});
    </script>
    And this now on the html page:
    <video id="vid2" class="video-js vjs-default-skin" preload="none" width="140" height="120"
    poster="http://www....com/img/test.jpg" controls data-setup='{}' controls>
    <source src="http://www....com/1video/test.mp4" type="video/mp4" />
    </video>
    Any comments or insight you can share will be appreciated.
