hello everyone.
i was wondering if anyone knows how to extract *all* of outlook's emails into a file, (csv or other) that i can import into an ms access database ?
this is so that i can do a better and quicker search for missing emails. i also have many emails that i drag into the left pane window into folders that i catagorize. i received hundreds of emails a week. maybe there is a place where a separate file is stored and i have to take that and decode it. if that is the case, hopefully there is a tool that knows how to decode the file so that i can import it into access database.
i am using two computers, one with office 2003 and another as office 2010.
thank you in advanced!
The Outlook emails are already in a "database": a PST or OST file (usu. hidden in a User subdir). What you need is a "connector" that can read the file natively and map it to how Access works so Access can access it. There is an "ODBC" driver that allows this and it includes a number of common database languages/protocols/formats. If Outlook connectivity isn't natively built-in, there should be a plugin for it.
With it, your email elements (to, from, cc, bcc, subject, body text, priority, datestamp, etc) can be mapped to fields that Access can directly manipulate in a standard Query (without having to convert/import).
Have done this a number of times so I know it works (well, at least with v2000, 2003, 2007 when I last attempted). Note that you will need to also have the info for user privileges (username, pwd, etc)-dependiing upon your setup this is sometimes persistently remembered, sometimes not.
Scott -
thank you.
i will look into that tomorrow. hopefully, i will be able to do something. i really just need for searching through things. thanks again. -
Outlook can export to a file, and there are numerous options (one of which is MS Access).
Google is your Friend -
Hi vhelp ,
Under XP , in the "Outlook Express's" folder there are many .dbx files .
Cheers .Code:C:\Documents and Settings\user\Local Settings\Application Data\Identities\{7188C653-6DB4-4093-B56D-7C575FED5F26}\Microsoft\Outlook ExpressJE SUIS CHARLIE !!! -
@aazerty, the OP was asking about Outlook, not Outlook Express. There is a big difference in their architecture & operation, (especially) including the file format and location of the user data. What you posted might be helpful to someone needing OE, but to vhelp this is useless.
not receiving emails in subscribed threads
By JohnnyBob in forum FeedbackReplies: 12Last Post: 16th Feb 2015, 14:14 -
M$ Outlook
By blinky88 in forum ComputerReplies: 3Last Post: 5th Feb 2013, 10:12 -
M$ outlook ???
By blinky88 in forum ComputerReplies: 9Last Post: 5th Apr 2012, 12:50 -
Convert multiple Thunderbird emails to a word file.
By lordhutt in forum ComputerReplies: 5Last Post: 14th Nov 2011, 12:13 -
winodws live won't receive send emails?
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 10th Nov 2010, 13:11
