Can you add a menu to avstodvd. I have added 2 movies to avstodvd. But need a menu added as well
Results 1 to 9 of 9
Has the interface changed so you do not have 'DVD-Menu' on the top menu bar ?
Open up the drop-down box there and select. -
You should do as DB83 says. Use the menu editor (DVD Menu). If you don't no menu is created.
Probably because your source video with built-in srt is not part of the dvd-spec. A dvd-authoring program will create the subs differently.
I do not know the answer but I suspect there is a setting that you can use so that the program will simply ignore the srt ie no subs. But if you want subs then you can not ignore it.
AVStoDVD
By Kolina in forum Video ConversionReplies: 6Last Post: 9th Jul 2014, 08:51 -
AVStoDVD help please.
By Erik419 in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2014, 16:02 -
AVStoDVD
By Tafflad in forum Authoring (DVD)Replies: 81Last Post: 5th Feb 2014, 08:03 -
ffdshow and AVStoDVD
By Hans L in forum Capturing and VCRReplies: 12Last Post: 20th Jun 2012, 15:28 -
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37
