How can I extract audio files from an ISO to a folder on my computer please?
	Thanks - yes I've got that. With the plug-in it allows you to PLAY the files, but I haven't found a way to extract the files to my computer.
	You need to do some SERIOUS reading:
 http://en.wikipedia.org/wiki/Super_Audio_CD
	Assuming the worst-case scenario:
 if you can play the stuff, then surely you can record it
 I *suppose* foobar2000 (or the SACD plugin) would not create an exception for SACD-content,
 i.e., by not letting the user call the context-menu entry named "Convert"
 I don't have any SACD .isos to test, so I cannot give a good answer to the doubt above
	UPDATE: just for learning purposes, I found and downloaded (&& tested && deleted) a "small" (1.6GB) SACD .iso file.
 Neither WinRAR nor 7-Zip are able to open the archive, which probably/apparently is encrypted.
 FWIW, foo_input_sacd worked as it should.
 Conclusion: it looks like you'll have to use the so-called "SACD Extract" utility:
 source: http://sacd-ripper.googlecode.com/svn/trunk/readmeCode:SACD Extract (available on Windows, Linux, OS X) allows you to extract individual tracks from ISO files when operated in file mode or from the SACD Ripper when operated in Daemon mode. The following options are available for the sacd_extract commandline tool: Usage: sacd_extract [options] [outfile] -2, --2ch-tracks : Export two channel tracks (default) -m, --mch-tracks : Export multi-channel tracks -e, --output-dsdiff-em : output as Philips DSDIFF (Edit Master) file -p, --output-dsdiff : output as Philips DSDIFF file -s, --output-dsf : output as Sony DSF file -I, --output-iso : output as RAW ISO -c, --convert-dst : convert DST to DSD -C, --export-cue : Export a CUE Sheet -i, --input[=FILE] : set source and determine if "iso" image, device or server (ex. -i192.168.1.10:2002) -P, --print : display disc and track information
 Good-luck with that.
	That's extremely helpful, many thanks. Something to get my teeth into.
 Cheers
 mike
  How do I extract VOBs from an ISO file? (ISO to VOB?)By Tearren in forum Video ConversionReplies: 6Last Post: 24th Jul 2013, 22:53
  Extract video files from a iso Like dvdfab does... FreewareBy RBCC in forum DVD RippingReplies: 4Last Post: 2nd May 2013, 22:39
  FFMBC: How do I batch remove all audio from MOV files in a folder?By newhampshirefarms in forum Video ConversionReplies: 2Last Post: 9th Oct 2012, 22:57
  How to extract audio from .vob filesBy webadm in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2012, 22:28
  Easy way to extract (demux) audio tracks from Blu-ray folder?By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 12:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
