please help ne on this,
I use ATI all in wonder to direct capture from to vcd format
120 kb/s audio---tried to change lower ,still skipping
use VCD Imager,and CDRWin for burning
have a new machine 1.6 G withlotsa memory
just wonder what seems to be the problem...
Have you actually tried capturing/encoding your video to the correct VCD specs?
http://www.vcdhelp.com/vcd.htm
Just having off spec VCDs can sometimes cause skipping by itself (regardless of whether the bitrate is higher than normal or lower than normal).
Regards.Michael Tam
w: Morsels of Evidence -
What speed are you burning your VCD's at? Try burning at a lower speed. I use 4X now as I have had audio skipping problems in the past which were solved by a lower speed.
Skipping audio problem!
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 11:02 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 02:31 -
MEncoder skipping frame with audio conversion
By Towin in forum Video ConversionReplies: 2Last Post: 24th Mar 2008, 11:08 -
Matroska Video - Audio delay when skipping
By strutter_uk in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2008, 11:08 -
audio skipping on video capture
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 18:18
