I'm trying to stream an 3d videos with 3d subtitle on my lg lb659y.
The movie is played well but the TV doesn't play the subtitles.
The type of the subtitles is sub/idx.
does someone have any solution?
mkv? half sbs or over/under? have you checked the owners manual for the lg? most likely it only plays text subs - .srt
AFAIK, nothing has changed in the last few months, so all the things that have been said here before (by me and others) are pretty much what will be available for you. This has been discussed many times.
Start off using MediaInfo to see what you have, compare it against what your user manual says is available to the PLAYER that is playing clips (whether TV's internal, BD player, general media player, htpc/software or whatever).
If you can't work out a match, you will have to convert til you get one. That match may end up being the last resort: burning-in your subs. But maybe not, if you are creative with your layout, rendering, etc.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
Forced Subtitles --> In Between Bit <-- Full Subtitles
By OzDrDj in forum SubtitleReplies: 0Last Post: 1st Jun 2012, 03:11 -
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
MKV with subtitles to MP4 with subtitles
By Evertype in forum Video ConversionReplies: 10Last Post: 6th Feb 2011, 14:43 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53
