Hello Gurus:
I forgot to remove my removable hard drive before I recovered my C: drive. The C: drive went well, but the removable drive only shows a folder name PRELOAD and a text file name MASTER.LOG. Any hope for me?
Hello.
Go to sevenforums.com ,there are many experts who will give you solid advice,dealing with this problem on a daily basis.
Try running the Windows checkdisk and getting it to check for file system errors. Is it still called chec-disk these days? I lost the contents of a 2TB external drive once. I'm not sure why, but I plugged it in and it looked almost empty. I ran checkdisk and it fixed the file system and I got access to everything back.
Other than that, the best "recovery" software I've used is without a doubt GetDataBack, but it's not free. I think you can download the trial though and scan drives, but the it won't recover until you buy it. Don't install anything on the drive in question, use it, or even look at it for too long before running file recovery software.
Assmuning that's what you're planning on doing...... and install the recovery software on another drive, scan, and preferably recover the files to a different drive too.
Recover deleted folders on external hard drive.
By hamilton accie in forum ComputerReplies: 2Last Post: 20th Oct 2014, 13:30 -
Recover files from formatted hard drive
By WinSpecToR in forum ComputerReplies: 7Last Post: 13th Mar 2012, 20:41 -
How do I recover the OEM portion of Hard Drive?
By TreeTops in forum ComputerReplies: 19Last Post: 21st Nov 2011, 01:53 -
newbie question pioneer dvr-433h hard drive restore?
By isakiel in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Nov 2011, 06:06 -
Recover Semi Dead Hard Drive
By imdaman in forum ComputerReplies: 7Last Post: 11th Jan 2011, 11:30
