I have received mkv files with 720 movie files before and have had no problems playing audio in Windows player or converting to vob, etc.
I have a new mkv that seemed to have no audio. It would not play with the video in Windows player. It seems to be non existant when opened in Cyberlink Power Director 8. I also had no luck with AVC Free. I checked and found that this file had DTS audio.
I put it into AVSTODVD and the audio file showed next to the video file before I clicked start. Several hours later and I have VOB files and still no audio.
There were a few comments at the source, but, none mentioned any audio problems.
Just what particular portion of my ignorance is getting in the way in this instance?
Thanks.
Results 1 to 17 of 17
Could you post the mediainfoxp information about the video?
newpball: attached as hhh.txt is mediainfoxp result DTS Home Theater. At this point I'd love to get even a clear 2.0 stereo.
Drat!! I did my usual glasses wearing smiley and it makes me look like a beach hipster.
How do you have sound configured on your PC.
Standard soundcard, audio interface, optical? -
newpball: it must be standard as it came with the PC.
[FYI: before I unchecked the 'Keep AC3/DTS/MP2 DVD Compliant Audio:' the whole process included 2 passes and a large window and took about an hour before the audio conversion window would pop up. Since then a smaller AVStoDVD window opens and it is 1 pass at about 40 minutes to the audio window.]
_MrC_: ASVtoDVD log attached -
My dear... you are using release 2.5.1, which is more than 2 years older than latest 2.8.1... see the link in my signature to download it.
Anyway, from the log file everything is OK, the source DTS audio track has been (on paper) correctly encoded and it is there as AC3 audio track in the output DVD structure. Have you tried to burn the DVD folder to a disc (better if RW, better with ImgBurn) and play the disc on your external DVD player?
Bye -
MrC. I burnt a DVDrw on the 19th . I use ImageBurn Free and always have had great results. How different is ImgBurn?
So there may have been a fix needed in the older AVStoDVD that should be fixed now, along with other good stuff. When I get the new one should I still unclick the preference newpball suggested? -
MrC: same result: original in VLC shows audio, result of AVStoDVD does not.
On setting up the new AVStoDVD I did not recognize what the default audio [thing] was: wavi + something. The other choices included 2 FFMPEG choices and since I had to add AVISYNTH to the program, I chose FFMPEG(AVISYNTH).
This time the video seemed to pass through and all the processing was the audio.
Log from AVStoDVD attached.
There were no comments about audio problems at the site I got this from. It was several years old.
Often my Cyberlink PowerDirector 8 is good enough, usually even for MKV. My next go to is AnyVideoConverter (free), but, since it is the free version is limited for problems like this. AVStoDVD is the last resort as it does so much that it has taken hours to finish. If not for the time involved I'd use it much more often. Although unclicking the audio pass through has sped it up these last tries. -
Again, also for this project (with 2.8.1 release) the audio has been converted from DTS (source audio track) to AC3 (output DVD audio track).
Now, if VLC is not playing audio I see 3 possibile causes:
1. VLC fails to play the AC3 audio track from the DVD structure
2. AC3 audio volume is too low
3. AC3 audio was not encoded properly
Possible investigations/solutions for each possible causes:
1. Try another software player (e.g. MPC-HC) or burn the DVD disc and play it with your external DVD player
2. Increase the volume of your speakers as much as you can
3. Try again with AVStoDVD, selecting 'FFmpeg Safe Mode' as AC3 encoder ('Preferences'/'Audio').
Now you have some homework to do....
Bye -
MrC: Selected FFmpeg Safe Mode and downloaded MPC-HC and played volume at high: no audio at all.
It has to be 3 AC3 audio was not encoded properly. Safe mode should have helped that, though?
In 2008 people were expected to have no problems and I saw no comments asking for help.
I had 2 files with the same problem. I ran the second one through with safe mode and it ended up with a soundtrack..with a 1.02 second advance. I put that one in the PowerDirector and synced it up. _Might_ only have 2.0 stereo after that, but I can hear it.
Is there anything different between log1 here and the other one? -
H viwerex,
the second log file is partial, could you upload the full log file?
'FFmpeg Safe Mode' should help to understand if you have any codecs issue, because it does not use codecs to decode the source DTS audio track, but instead directly encode the DTS track to AC3.
Do you have the possibility to upload one of the problematic MKV files? Or a portion of it (you can use Avidemux or MKV Cutter).
Bye -
MrC: I am not to sure what I did or did not do the first time after the suggested changes, but, I ran it through AVStoDVD again and this time had audio, again with a 1.02 second advance.
I ran it through the PowerDirector 8 and synced it up. The PD8 took the file size down and may have limited the audio possibilities but is just fine for me.
I am not sure why an attached log would not come through whole.
Once it seemed to work out I deleted everything [I am approx 100G away from being full and am always deleting.]
I watch these things on a 32" CRT analog. They still look good on the 21" monitor, so I am satisfied and could not possibly gotten to this point without your help, Thank you very much.
https://forum.videohelp.com/images/smilies/smile.gif
[I see no 'solved' box to tick]
Extracted audio from MKV--how to convert .DTS audio file?
By mindstormer in forum AudioReplies: 7Last Post: 18th Nov 2014, 09:40 -
MKV source AC3 audio = no audio in encoded file
By trodas in forum Video ConversionReplies: 0Last Post: 9th Oct 2013, 19:19 -
Ass file with script mkv file problem
By Docoptik in forum SubtitleReplies: 9Last Post: 25th Mar 2013, 14:44 -
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32
