Results 1 to 21 of 21
    Sep 2014
    Rome
    hi
    may i ask 2 questions?
    1)
    i want to change speed in premiere cc only the video speed for a small selected part of my video
    i select mark in and out to select the part i want to slow down
    after in effect controll i want to use keyframe to change speed
    can i zoom in in the timeline ?
    i create several keyframe , i want to slow down the video speed and set to normal speed
    but i can't zoom in and be precise
    i would like to zoom where are the red arrows in the screenshots
    thanks
    2)
    i want to apply effect only on a part of the video , like use the contrast effect on a selected part of my video
    is the razor the only way ,isn't it?
    thanks
  2. You zoom in and out of the timeline using the + and - keys. There are also sliders near the bottom. The razor is not the only way, but it's usually the simplest.
    Sep 2014
    Rome
    hi
    i have premiere cc pro but + and - don't work , i use it under w8.1
    maybe because my keyboard is in my native language and i have installed premiere in english
  4. Banned
    Oct 2014
    Northern California
    Use an adjustment layer placed exactly over the region you want adjusted.
  5. Originally Posted by rama View Post
    Under Edit/Keyboard Shortcuts you can modify the keyboard commands any way you prefer. The function is called zoom in, zoom out.
    Apr 2003
    And also keep in mind that the + and - keys for zooming in and out are NOT the + and - on the numeric keypad. The ones on the numeric keypad perform different functions by default.
    Brainiac
    Sep 2014
    Rome
    thanks
    i did it ,and now works !
    Sep 2014
    Rome
    hi thanks
    i tried and works
    but i have noticed that with some effects like black and white , the opacity and keyframes don't work
    i tried to add several keyframes with different opacity values, like the first 0% (no effects) after 50% and 70% and so on
    i tried another effect (contrast) and it works
    why?
    thanks again
  9. Banned
    Oct 2014
    Northern California
    Well perhaps because black and white is a black and white (pun intended) effect.
    After all there is no such thing as a little bit black and white.
    However you could use saturation and keyframe that, that should work.
    Sep 2014
    Rome
    hi
    can you try it if you have premiere cc ?
    because sometime i think there is some bugs in the last built
    yes ,instead i did
  11. Banned
    Oct 2014
    Northern California
    hi
    Just tried it and it does work!
    Black and white in the adjustment layer is sensitive to the opacity, it works effectively like a saturation adjustment.
    Sep 2014
    Rome
    hi
    thanks
    i guess i got a buggy version , sometime i think about cs6!
    i'm running cc under w8.1
    Sep 2014
    Rome
    [QUOTE=newpball;2386327]
    hi
    strange , i tried black and white on videos , titles and so on and the opacity works
    with adjustament layer ony the first keyframe works
    for example i set the fist keyframe at 0% and the second at 100% -> the video is all in color
    i set the first keyframe at 100% and the second at 0% -> the video is all in black and white
    may i know which premiere version do you have ?
    thanks
  14. Black and White is not a keyframable effect in and of itself. If you create a mask within it, the mask parameters can be keyframed. If you use it on an adjustment layer you can keyframe the opacity, size, etc. of the layer.
    Adjustment layers are best used when applying the same effect over a range of shots. If you are applying the effect to a single shot it usually makes more sense to apply the effect to that shot directly. If you are using an effect for part of a shot, best workflow is generally to do keyframing within the shot or use the razor tool to split the shot into effected and non-effected parts.
    Using an adjustment layer over part of a shot means you now have two things to move when you rearrange your sequence -- more things to keep track of, more things that can go wrong. I would discourage that method in this situation.
    Premiere has been pretty stable since at least CS5. If you're using a lot of long-GOP footage or an underpowered computer, those can be contributing factors. It's a good practice to purge the media database and disk cache from time to time as well.
    Sep 2014
    Rome
    hi
    thanks for the answer
    sadly english is not my native language
    about my #13 , are you saying it's the design of black and white effect on an adjustamanet layer ?
    if i want add an adjustament layer and use a black and white on it , and controll the opacity on several keyframe ,do i need the mask ,don't I?
    because according my #13 , premiere doesn't care about all the opacity keyframes outside the first
    thanks
  16. Black and White is not a keyframable effect in and of itself. You must choose a mask within it. The mask parameters can be keyframed.
    If you are doing this all correctly, there is likely a problem with your installation.
    Sep 2014
    Rome
    hi
    thanks a lot
    i have not masks
    there is the screenshot and i watched this video https://helpx.adobe.com/premiere-pro/how-to/blur-face-masking-tracking.html
    look the screenshot there is no masks
    here i found in the adobe forum https://forums.adobe.com/thread/1479955
  18. Originally Posted by rama View Post
    i have not masks
    Okay, so that function was added in a later version. In that case, if what you're trying to do is make an image go from color to black and white, use an adjustment layer, apply the black and white filter to the adjustment layer, and modify the opacity of the adjustment layer.
    But again, I'm only guessing at what you're trying to do. Let's work from the results you're trying to accomplish, not the process you're trying to use.
    Sep 2014
    Rome
    i have not masks
    hi
    i'm going to update premiere , weird , masks are present in cs6 and cc but not in the cc 7.2.2
    thanks a lot Smrpix
  20. Originally Posted by rama View Post
    The latest version is 8.2.0. Since you are subscribed to CC you are entitled to be up to date. 7.2.2 is an unstable version that appears to be widely circulated by hackers and thieves.
  21. Banned
    Oct 2014
    Northern California
    Talking about Premiere versions, new stuff coming down the pipeline:
    Especially the color stuff will be useful.
