I've got a couple of BD rips that are stored as BDMV folders on my harddrive. What I'd like to do is remux those folders into mp4 or mkv files, without having to touch the video or audio tracks. Only thing I'd like to change is deleting some of the audio tracks I don't use.
Is there any easy way to do this on a Mac?
Makemkv . The beta is free. See http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Thanks, but I've already tried Makemkv. All I get is an "can't write to disk" error message when I try to remux an index.bdmv to mkv.
Code:MakeMKV v1.9.2 darwin(x86-release) started Debug logging enabled, log will be saved as /Users/TOMillr/MakeMKV_log.txt Optical drive "DVD+R-DL HL-DT-ST DVDRW GSA-S10N AP12" opened in DASPI v1.5 mode. DEBUG: Code 0 at 4W`EsM/Np{-F(x}L~"ib0<(v5:213131318 Opening files on harddrive at /Volumes/Backup/Vertigo/Vertigo AACS directory not present, assuming unencrypted disc Evaluation version, 30 day(s) out of 30 remaining File 00000.mpls was added as title #0 Operation successfully completed Saving 1 titles into directory /Volumes/Backup/Vertigo DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at X-k"`^X>Jc1zI,$o:213131640 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at %3]U24E&Cy/4B4f=4:121264073 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at X-k"`^X>Jc1zI,$o:213131640 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at %3]U24E&Cy/4B4f=4:121264073 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at X-k"`^X>Jc1zI,$o:213131640 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at %3]U24E&Cy/4B4f=4:121264073 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at X-k"`^X>Jc1zI,$o:213131640 DBG ASSERT: %E1HQe6)$uJ jY(1|<ft%<] at %3]U24E&Cy/4B4f=4:121264073 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF) Failed to save title 0 to file /Volumes/Backup/Vertigo/title00.mkv 0 titles saved, 1 failed -
And you can write to that folder without problems?
Or try mkvmergegui (if it's available in the mac mkvtoolnix package) and add the biggest m2ts file. Make a new mkv.
Or try tsmuxer for mac and open the mpls playlist, output as a single m2ts. Open in mkvmergegui and make mkv.
Or dual boot into windows.
Yes, I can write to that folder without any issues. I've also tried pointing the output file on the desktop but I still get the same error message.
But I'm gonna give the other two tools I try and report back.
How to easily convert a Blu-ray to MP4/M4V/MKV using free tools
By Baldrick in forum User guidesReplies: 18Last Post: 29th Mar 2018, 03:20 -
Create MKV from a BDMV folder?
By elcoyoteloco in forum Blu-ray RippingReplies: 17Last Post: 4th Feb 2018, 05:06 -
How to easily convert DVD to high quality MP4/MKV H264 using free tools
By Baldrick in forum User guidesReplies: 45Last Post: 25th Jul 2017, 23:35 -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39 -
Can't upen BDMV folder with BDInfo on Mac OS X
By naiera in forum Blu-ray RippingReplies: 9Last Post: 20th Dec 2012, 14:38
