For some reason I can not get MediaInfo to work on my computer, it will not load up at all on this machine. It works just fine on my other laptop that runs Windows 7 but not on the desktop that runs Windows 8.1. It will not even progress to the screen asking whether I want to install the program it just shows a loading icon for a brief moment and then nothing else happens. So I was wondering if there is something I'm doing wrong or if there is another program that will do basically the same thing as MediaInfo that I could try to run to get the information that I need.
Have you tried running the installer as admin? Right click on it and you should see that option.
Yeah I've tried that, I don't know if I just have a piece of crap computer or what but it's pretty new I've only had it a few months, but there are certain things it just won't let me do. I cannot even get the command prompt to open with administrative rights either and I've had problems with a few other programs in the past where it would do pretty much the same thing as it does with MediaInfo. It is very annoying and I don't know what else I can do. I've resorted to transferring the media to my laptop via a flash drive just to get the info I need but it would be so much better if I did not have to do that all the time.
Try run portable version that not need to install
just extract from zip and run: for Windows 64bit version or 32bit version
If you don't know how to extract 7z file
use 7zip or WinRarLast edited by roma_turok; 17th Apr 2015 at 22:35.
Do you happen to be running "Avast" as your antivirus? If so, Avast has a built in "file system shield" and likes to hinder anyone installing programs. Avast>>>Settings>>>Active protection>>> And disable/postpone to install. I mention Avast, because I ran into this problem trying to install certain programs. If this doesn't help, I apologize as I have windows 7.
This film is presented in it's original 2.35:1 aspect ratio. The black bars at top and bottom are normal. (it's you that isn't normal) -
mediainfo 773
By mysts in forum EditingReplies: 2Last Post: 13th Apr 2015, 19:37 -
MediaInfo CLI - C#
By Keller501 in forum ProgrammingReplies: 12Last Post: 30th Jan 2014, 21:57 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 22:22 -
[MediaInfo] What exactly is bitrate ?
By Klagar in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 09:54 -
MKV mediainfo questions/advice
By CoopOwnz in forum Newbie / General discussionsReplies: 3Last Post: 12th Oct 2010, 04:29
