  1. Hello Friends,
    I want to play a mp4 file on my SONY TV.
    You can see ports of my tv in the picture:
    I want to know about device in which i copy video file from pc,then connect it to tv and tv play that file...??
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    There is nothing on the back of the TV?
  3. This the back picture of TV
  4. You're going to need a media player to do what you want with that TV...maybe something like THIS for example?
  5. bro the device u mentioned,it's ports are different they are like usb type
  6. You need to use the 'composite' output from the device , and connect to the TV RCA sockets with the cable supplied. See the spec HERE
    There's a picture of the connection used on page 11 of the manual for the earlier model HERE It's the same thing for the newer model
