    Mar 2015
    Cameroon
    My friend and I are thinking of making videos like this tutor's for our exhibitions.
    http://http://opentuition.com/acca/f7/group-accounts-an-introduction/
    From around 01:17 a white screen - that fills the frame - is being written on, but we don't see the hand but just the scribbling. I know he's writing on some kind of gadget that produces that, and the output is probably visible and recorded on his computer?? I don't want to make any assumptions....
    What's that gadget called (a shop link would be great)?
    And how is the combination done that the magic writing goes on and the tutor's frame is inserted Below Right of the main screen? I dunno if it's a basic picture-in-picture effect?
    Basically can someone pls kindly tell me...
    1) The equipment I need, and
    2)The set-up or arrangement...
    to come out with a video like this; including the way with the insertion?
    Thanks man
  2. Banned
    Oct 2014
    Northern California
    You could use an Elmo for that!
  3. Member Cornucopia's Avatar
    It's called a video "Whiteboard".
    The insert of the speaker IS a PiP effect (either realtime using Tricaster or similar, or after the fact using any good NLE).
    Mar 2015
    Cameroon
    Dears...can't thank you enough for your patience. This is very important to me. I am trying to check out the equipment and software, and see how to use what you said.
