Thanks for the quick response.
I am relatively new to the actual doing in avisynth (have scanned hundreds of hours of 8mm film over the years), as I mainly had been reading about Avisynth over the years and seen people manipulate the scripts.
Over the last couple of weeks, I have been experimenting with Fred's script via a third party interface (with good results), so haven't really even got my hands on to the scripts alone.
As a result, I haven't experimented with Stack16 yet. Just read whatever web ressources I could find on it (forums such as doom9, wiki etc.) trying to get my head around it, so I could start playing with it.
I will share some of the results on the forum to give you an idea of what the originals are like and the restored and stabilized versions. (I may also report on the time it takes to encode at various colour bit depths)
By the way, am I correct in assuming that I would only need to use dither scripts/plugins once I am going from a 16bit input to a 12bit output for instance?
I know Fred also has an improved version of his script running on AvsPmod, so have been considering that as well.
Results 91 to 93 of 93
I just keep getting an error that says DePanEstimate does not have a named argument "improve" when I try to use stab2()
iMovie and Stabilization
By zoranb in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2014, 07:25 -
Help with Stabilization
By henryperu77 in forum RestorationReplies: 6Last Post: 1st Apr 2014, 20:35 -
Noise coming from DSLR objective's Optical Stabilization
By diffler in forum AudioReplies: 4Last Post: 11th Mar 2014, 00:19 -
Limiting the amount of zooming After Effects is doing during stabilization?
By kingmustard123 in forum EditingReplies: 3Last Post: 3rd Jul 2011, 10:12 -
Does stabilization effect image quality?
By davidjon54 in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 18:03
