  1. Hey... I've been trying to tip this "f4m" based live streaming,but, can't seem to work it out. I tried using adobeHDS php script and it shows that I need to install curl. But, Curl is already installed in my system!. It's installed as a global variable and I can use it from anywhere in my system and same with php.
    The live stream I'm trying to RIP is this :-
    http://www3.nhk.or.jp/nhkworld/w/movie/
    HDS Link detector gives me this string :-
    php AdobeHDS.php --manifest "http://nhkworld-hds-live2.hds2.fmslive.stream.ne.jp/hds-live/nhkworld-hds-live2/_definst_/livestream/nhkworld-live-512.f4m" --delete
    I have this adobehds.php in my system. I try to rip and says I need curl. What do I do.? any help would be appreciated
    Some screen shots
  2. hi you can use livestreamer
    livestreamer "hds://http://nhkworld-hds-live2.hds2.fmslive.stream.ne.jp/hds-live/nhkworld-hds-live2/_definst_/livestream/nhkworld-live-512.f4m" best -o nhkworld-live.flv
  3. Originally Posted by biezom View Post
    Ohh.. thanx a ton mate.!! I tried it , but it didn't work... so, I tried posting in the forum and look it's working THANX ^_^
