I used cladDVD XP to rip an entire DVD to my hard drive. As is typical, the entire movie won't fit on a DVD-R but the one VOB that has the actual movie does fit. What is the best way to get the single VOB on a DVD?
Do I edit the IFO files to have one VOB on the disk? How do I do that?
Is there a DVD burner like DVDIT that will take a VOB file in?
Any advice appreciated.
Rob
reRip the movie using smartripper in using "movie" mode or "files" mode...these modes will automatically only rip the main movie...if you enable "stream processing" in movie mode the movie will be ripped into a .m2v file for the video and a seperate file for the audio...these files can be easily imported into nearly all DVD burning programs...for more detailed instructions refer to http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs/ or www.dvd2dvdr.com
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 17th Feb 2012, 00:54 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 17:49 -
Want to put the dvd in my dvd player and it plays, no frame selection.
By LauraSpring in forum Newbie / General discussionsReplies: 3Last Post: 15th Nov 2009, 18:29 -
How to separate audio from VOB, change it and then put it back?
By jatemail in forum EditingReplies: 1Last Post: 18th Aug 2009, 01:44 -
how can I rip my dvd tracks to individual .VOB file?
By dannieboiz in forum DVD RippingReplies: 6Last Post: 16th Jan 2008, 21:27
