Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jul 2002
    computer=windows 8.1
    Just installed mediainfo 773. It does not appear in the shell when right clicking a file. Has this happened to anyone else?
  2. Did you try enabling its shell extensions? Options -> Preferences -> Setup -> Explorer extension...
    Jul 2002
    Thanks jagabo
    Yes I checked all the choices but no go. The setup looks the same as an older version on another computer but for some reason this one doesn't work.
