I am capturing AVI using Virtuadub set to 25fps 22khz stereo with huffy codec. dropped 1 frame every six seconds regular as clockwork, first time round captured fine an entire film, encoded using tmpeg and burnt using Nero film came out brill. Windows locked up after reinstalling it now drops frames allover unwatchable outcome. Tried deintalling the codec virtuadub and hardware but still no good. any ideas?.
try using some video buffers, goto capture/settings ,under video buffer limit try sticking in 100, it works for me...
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 10:00 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Mute a part of the Audio
By Flowbax in forum AudioReplies: 3Last Post: 25th Jul 2007, 08:46
