Is there a tool thats free thatbi can from cbs.com&nbc.com? Besides a cap r ure program?
Or a capture program that captures multiple videos and saves them on my hard disk? John
Results 1 to 9 of 9
Hi, if you opt for screen recording you can use fraps or camstudio for example.
You can also use a screen recorder who works with a webcam.
Otherwise there were other people who tried to download videos from cbs:
There is also a method which can be use with rtmpexplorer but I don't know if it still works :
https://www.youtube.com/watch?v=RmUOi1HEbuY
I don't know too much about that kind of download but I try to help in any case. -
Ok thank you maybe someone else has ideas??? Maybe a screen capture that b allows u to capture in sequence?????John
Hi RBCC ,
Here below 2 examples of kind of links able . Instructions are just for see the streams inclued .
Cheers .Code:==== ffmpeg -i http://ipad-streaming.cbsnews.com/media/mpx/2014/12/01/365384259587/48_112214_newepisode_314665_1800/48_112214_newepisode_314665_1800.m3u8 ... Input #0, hls,applehttp, from 'http://ipad-streaming.cbsnews.com/media/mpx/2014/12/01/365384259587/48_112214_newepisode_314665_1800/48_112214_newepisode_314665_1800.m3u8': Duration: 00:42:43.00, start: 0.000000, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540 [SAR 1:1 DAR 16:9], 14.99 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 22050 Hz, stereo, fltp, 38 kb/s ==== ffmpeg -i http://download.cbsnews.com/media/2014/12/01/365384259587/48_112214_newepisode_314634_796.mp4 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://download.cbsnews.com/media/2014/12/01/365384259587/48_112214_newepisode_314634_796.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : Lavf55.19.104 Duration: 00:42:51.24, start: 0.000000, bitrate: 807 kb/s Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 698 kb/s, 29.97 fps, 29.97 tbr, 11988 tbn, 59.94 tbc Metadata: handler_name : VideoHandler Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 69 kb/s Metadata: handler_name : SoundHandler Stream #0:2(und): Data: none (rtp / 0x20707472), 26 kb/s Metadata: creation_time : 2014-12-01 01:55:55 handler_name : GPAC ISO Hint Handler Stream #0:3(und): Data: none (rtp / 0x20707472), 8 kb/s Metadata: creation_time : 2014-12-01 01:55:56 handler_name : GPAC ISO Hint Handler ====JE SUIS CHARLIE !!! -
ChrisPC VideoTube Downloader can get videos from cbs and nbc
Is there a capturer that can capture more than one stream at a time? John
Can you allude to how low of quality you are referring to? Also can i get rid of the proxy error message i keep getting? Does it have something to do with the video quality? John
Where does this go? Has anybody had any luck downloading off the NBC/CBS?
By RBCC in forum Newbie / General discussionsReplies: 11Last Post: 14th Nov 2014, 05:28 -
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 3Last Post: 20th Sep 2014, 14:06 -
How to record part of live stream m3u8(30min)& save it as mp4 using ffmpeg?
By spiderMan007 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Mar 2013, 17:54 -
how to convert and save audio & video files? how large of a HD?
By speone in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 13:55 -
Tool to batch download, save and rename QuickTime stream files
By oediv in forum Video Streaming DownloadingReplies: 8Last Post: 24th Dec 2011, 17:24
