I finally divined the secret of getting my LG Blu-Ray player to play 4:3 DVD's in the correct AR instead of stretching them. There's a setting for two 16:9 modes - 16:9 "Original" and 16:9 "Full".
It's not clear to me why there are these two modes. In 16:9 Original, you put in a 16:9 disc it plays 16:9, put in a 4:3 disc, it plays 4:3. In 16:9 Full, everything gets stretched to 16:9.
Any insights as to why these two modes exist?
Thanks.
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Both exist because some people don't care about seeing movies in their original aspect ratio. They want the video to completely fill their TV's screen.
There are posts here on that subject from time to time, mostly by newbies, who are unhappy when the screen is not filled. Astonishingly, I've seen occasional posts at AVS too complaining about the same thing, from members with more than a hundred posts. Some will side stretch 4:3 material (aspect ratio be damned), and will zoom letterboxed 16:9 movies, despite the resultant cropping. What they really need is a bigger TV.
The terminology used by your player could be better, though. On a 16:9 TV, your 16:9 Original seems to give "dot-by-dot", while 16:9 Full is probably "side-stretch". Just to use the viewing mode terms from the Sharp TV I'm using now. There are others, and it seems each manufacturer has their own viewing mode terms.Pull! Bang! Darn!
Blu-ray player to play "X-Men: Days of Future Past" blu-ray
By nekros111 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Sep 2015, 04:06 -
Can Someone Recommend a Blu-Ray Player that can read "BD-R" & "DVD-R" ?
By THEBDC in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Mar 2015, 18:03 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 05:23 -
x264VFW: settings to achieve "same" original quality
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2014, 18:41 -
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 19:34
