Hi;
This is my first post here.
I'm looking for information and/or programmers for a job that requires the following:
I need a DVR with multiple video sources to create a SINGLE H264 file with up to 8 video sources.
I then need to be able to produce/use some sort of a viewer that will allow me to view the video sources from the single file and switch sources on the fly.
I appreciate any help/resources you would provide me with.
Thanks,
AK
Welcome to the forums.
You're going to have to provide more information. For starters, what is this, a security system? A TV show? A webcast? A lobby installation? -
smrpix - Its a new idea which I'm trying to develop myself. It has to do with security, but not exactly. I don't want to get into the exact application since as far as I know it hasn't been done yet. But generally the idea is this: A DVR would record up to 8 video sources into one H264 file. Then that file would be used to A- view and select different video sources on the fly, and B (which I did not mention in my original post) - create a new video file which is the result of the user's selection of the different video sources. So for example if the user selected certain cameras during his 'preview', a new file would be saved to the hard drive which would be a one stream video with the combinations the user did so he can basically watch his selection again.
I have seen a security system by Avertex which does the first part - creating a single H264, but its their own propitiatory format so I can't really use that.
I hope this helps.
Thanks,
AK -
I was a bit thrown off by your specificity about using a DVR and a single multiplexed stream of 8 videos. What you're describing appears to be run of the mill multicamera production.
www.Newtek.com/products/tricaster-8000.html
Capturing DVR HD Programming
By TonyK66 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Feb 2013, 14:52 -
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 05:38 -
Question About TIVO DVR Timer Programming
By Frank-0-Video in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2012, 10:39 -
Audio/Video multi format/source selector
By YesRushGen in forum DVB / IPTVReplies: 0Last Post: 14th Jan 2011, 18:06 -
New to video programming, need guidance
By iangard in forum ProgrammingReplies: 0Last Post: 28th Apr 2010, 08:48
