Hi everyone. I'm Artemis. New in the forum.
I've bee trying to get an used VHS camera recorder from the 80s, which i got. The wonderful Panasonic Omnimovie VHS Newvycon.
I just bought from EBAY and it worked wonderful for a few minutes. I tried to filmed me, which i did very succesfully, i put the virgin tape, everything was fine.
The problem started when i began trying vhs movies i had - with this camera you can also watch your own vhs films - And they all were fuzzy, which i don't understand. but the biggest problem of all is that the last vhs i tried is now inside the camera and the camera SHUTS DOWN ON ITS OWN. i tried to re-start it and it shuts down again every 5 seconds, with the tape rolling.
So basically now it's the same thing
1) I turn on the camera,
2) It makes some sounds, like moving the tape, everything is working
3) It shuts down, after 5 seconds
I just don't know whato do. I'm desperate. I just got it and i seriously don't know what's wrong with it. Maybe some cool expert here can help me out. I appreciate it.
Couple of common possibilities:
Water/Humidity (not too likely)
Overheating
Tape jam (quite likely)
If the last, there was an old trick that would sometimes work-power up the cam and immediately/already have the eject button held down.
Otherwise, you will have to dismantle the cam in order to retrieve the tape. Regardless, that cam isn't worth the effort to fix.
Scott -
Certainly something that could be of interest for collectors.
In that case you would leave it exposed permanently in some glass cabinet.
If however your intent was to actually use this then you just made a very bad buying decision.
Out of curiosity how much did you pay for this?
Another Nightmare Disc
By hech54 in forum Authoring (DVD)Replies: 14Last Post: 2nd Aug 2013, 07:44 -
Beginner heeds help with
By garebo in forum Video ConversionReplies: 2Last Post: 5th Jun 2012, 13:37 -
Mkv Nightmare!
By Soixante in forum Video ConversionReplies: 3Last Post: 19th Nov 2011, 05:51 -
DVD ripping nightmare
By julius02 in forum Authoring (DVD)Replies: 22Last Post: 17th Aug 2011, 16:02 -
Can this 3 step nightmare be simplified?
By gene0915 in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2011, 21:54
