Hi all,
I repeatedly get the following message whenever I try to convert a video in MP4 with VLC, v 2.2.0.
This is my translation from French.Transcoding failed.It appears that your installation of Libav/ffmpeg(libravcodec)does not include the following encoder :
« MS MPEG-4 Video v1 » Do not contact VLC for this.
How can this be fixed?
Thanks.
Results 1 to 13 of 13
Upgrade your Libav/ffmpeg(libravcodec), or enable that codec. If you use a codec pack, like K-Lite, you can configure which encoders/decoders are active.
yes,tanks budwzr,your answer looks like something I expected.
Howevew, can you give me a tip on where this could be located. -
"MS MPEG-4 Video v1" -> you are aware that 'MS MPEG-4 Video v1' isn't even MPEG-4 compliant?
+ afaik v1 was never added to libav, only v2&v3 were (which also are not MPEG-4 compliant)
-> unless you a. have a vfw "MS MPEG-4 Video v1" encoder and b. VLC can use that encoder, using vlc will probably not help
(I also doubt that any recent encoder tool will support "MS MPEG-4 Video v1")
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Likely that VLC version was older
Selur is correct - msmpeg4v1 as an encoder was dropped from libav, thus you cannot encode using that with newer VLC versions. Download an old version and you should be able to (but that means you won't be able to decode newer formats, like HEVC)
Here is a (ffmpeg) version fom 2010, the "E" means encoder is available
DEVSD msmpeg4 MPEG-4 part 2 Microsoft variant version 3
DEVSD msmpeg4v1 MPEG-4 part 2 Microsoft variant version 1
DEVSD msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2
Here is a (ffmpeg) version fom 2015, the absence of "E" means encoder is NOT available
D.V.L. msmpeg4v1 MPEG-4 part 2 Microsoft variant version 1
DEV.L. msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2
DEV.L. msmpeg4v3 MPEG-4 part 2 Microsoft variant version 3 (decoders: msmpeg4 ) (encoders: msmpeg4 )
Is there any reason why you need ""MS MPEG-4 Video v1" ?
Unable to open stream in VLC (log included)
By mortpiedra in forum Newbie / General discussionsReplies: 0Last Post: 5th Apr 2015, 14:15 -
Convert composite to IP with VLC
By ricardoRF10 in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2015, 12:56 -
Urgent VLC is unable to open MRL http
By Sam Qur in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Apr 2014, 11:57 -
unable to convert full video from mkv to mp4
By srikanth3d in forum Video ConversionReplies: 1Last Post: 21st Apr 2013, 12:59 -
How use VLC to convert Youtube flv files to other video formats?
By solarblast in forum EditingReplies: 1Last Post: 24th Jul 2011, 13:43
