Hello, dear all.
As the title says: How to Mux / Join Audio & Videos Files From "Keepvid" site and Similar Ones?
For example: if I go to : http://keepvid.com/
And can get all the links from there ( audio and video files) and want to mux video and audio files, how to proceed?
Oh, almost forgot to say: I'm talking about links obtained from Youtube site. Maybe other sites works like the same way too.
Which programs can do that for me? ffmpeg is one of them? Any manual / tips how do to it using ffmpeg?
My goal is to pick up the best resolution videos like 1080p / higher (Video Only) and mux it with any audio available there.
Is that possible? Any convertion is possible concerning all 1080p / higher (Video Only) and audio files?
Thanks for helping.
Best regards.
devil (johner)
You can mux with mymp4boxgui or mkvmergeui.
Or use other download apps like https://www.videohelp.com/software/4K-Video-Downloader , freemake video downloader, masstube that should get one video file. -
Hello, dear all!
Thanks for helping!
I really enjoy 4kvideodownloader! :P
But, I could notice some "differences" when I download some videos using: 4kvideodownloader, "keepvid.com" site and and Video DownloadHelper.
I could grab 1080p (Video Only) using "keepvid.com" site. The video has no sound. See what I could find about its videos using MediaInfo:
Duration : 58s 226ms
Overall bit rate : 2 649 Kbps
Encoded date : UTC 2014-08-11 02:34:14
Tagged date : UTC 2014-08-11 02:34:14
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate : 2 647 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.000 fps
Minimum frame rate : 23.974 fps
Maximum frame rate : 857.143 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.053
Stream size : 18.4 MiB (100%)
Such video has no sound and and strangely is not seekable. No player can seek it. Only play or pause the video. Not convertions is possible too!
When I try to open it using Avidemux I cannot do it. Error. It seems no muxing is possible too!
When I try the program 4kvideodownloader on the same link I could get the video + audio
perfectly. See what MediaInfo says about it:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 20.2 MiB
Duration : 58s 375ms
Overall bit rate : 2 899 Kbps
Writing application : Lavf55.33.100
Video
Format : AVC
Codec ID : avc1
Duration : 58s 225ms
Maximum frame rate : 90 000.000 fps
Color space : YUV
Bit depth : 8 bits
Stream size : 18.4 MiB (91%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 254 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 1.76 MiB (9%)
And when I use Video DownloadHelper I could get the highest resolution available!
The problems is that now such program put some "watermark" when convertion is done using such program.
The current / newer versions need registration to remove the watermark.
No problem at all, because I do not mind to pay for it.
I just wanna know if does not exist freewares available that can get such video / audio just like Video DownloadHelper does.
Comparing the same grabbed files using Video DownloadHelper and 4kvideodownloader it seems that ones from Video DownloadHelper have better quality that 4kvideodownloader can provide. Does it really true and happen indeed?
Even the sizes of them are different: from Video DownloadHelper has 29 Mb. And the 4kvideodownloader file has 20 Mb. Both in MP4 container. And all the resolutions grabbed are the highest that such programs can provide on their engines.
Maybe Video DownloadHelper could grab/ convert on higher resolutions that the others couldn't?
If I can't find freewares that can do it the grabbing in hightest resolution available I'll buy a license from Video DownloadHelper.
I just want to undertand the "differences" between programs and all outputs from them.
Thanks for the tips!
Best regards.
devil (johner)
HOW TO Multi subtitle & .mkv files mux [HELP]
By MoleofWar in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2013, 12:28 -
By MoleofWar in forum SubtitleReplies: 1Last Post: 17th Oct 2013, 02:31 -
Join video files without reencoding and save/load order of videos
By Danielyt in forum EditingReplies: 6Last Post: 1st Nov 2011, 12:27 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34 -
Mux many audio & video files to avi
By Urban20 in forum EditingReplies: 3Last Post: 29th Apr 2010, 04:35
