Slysoft has been asked for some type of Cinavia removal for years now, and they've finally come out with something. You'll need both AnyDVD HD and CloneBD to remove the watermark, and you'll lose the HD quality. The process requires converting to AC3 audio with CloneBD.
There are some samples at MyCE, which you can hear in this article: http://www.myce.com/news/slysoft-removes-cinavia-signal-from-blu-ray-movies-with-anydv...ination-75695/
I've listened to them several times, and its just not a great solution. The sound has a weird, warbling, echoing effect. This is most evident in the second sample, with the sound from the helicopter.
Results 1 to 30 of 63
wonder how long this program will last once hollywood get's wind of this.
Kerry56
What is your opinion of the resulting sound quality.
Comparison to Cin EX -
Gonca
I'd like to make a longer sample than what we've heard at MyCE. I don't own CloneBD, but I assume it will work even in trial mode for this. Right now my opinion is that it is not as good, but I would like to hear more examples.
The audio from the last version of CinEx was fine, not distinguishable from 192kbps bitrate AC3 from a DVD in my opinion, and that may be the origin of those "database" files. No one has ever proved that one way or the other.
Unfortunately, I deleted all my CinEx files a long time ago. I can recreate them, as I still have access to the database files I believe. -
I don't have that many movies with Cinavia. I'm going to try The Girl with the Dragon Tattoo (US version). Looking at the dialog, then the motorcycle chase scene at 2:07 or so. I want to see if the sound of the motorcycle distorts like the helicopter in The Hunger Games Mockingjay Pt. 1.
I do have Mockingjay Pt. 1, so I might try another section with it. Perhaps the storming of the dam at 1:10:30. -
I used CloneBD to make an MKV file from The Girl with the Dragon Tattoo (US). Tried to cut out a section with AviDemux but couldn't find any I frames, and it crashed the program cutting on P or B frames. Cut out a section with VideoReDo TV Suite. Videoredo balked at the DTS HD audio however, and had to use AviDemux on the original.
I tried the motorcycle scene, but the background music is too weird to make judgements.
These audio clips are from the scenes where Daniel Craig is shot, and is running. The sound of the 2nd gunshot is odd in the version with Cinavia removed, and overall the sound is off. First clip is the original:
Original audio GWTDT.mka
Cinavia removed clip from GWTDT_Track01.ac3
The dialog at the end isn't too bad, but seems a little hollow?Last edited by Kerry56; 9th Apr 2015 at 22:39.
Being relatively new to BD ripping, can I ask what may seem an obvious question. Just to see what the Cinavia stuff was all about I recently ripped The Social Network - obviously the Cinavia remains intact.
But if Cinavia is unbreakable and so good why isn't it used on more BD's, is it a matter of licensing costs or such like? -
Only one company, Sony Pictures Entertainment, uses Cinavia on many of their movies. A few of the other studios have used it on select movies, but as you have noted it isn't common. We assume it is licensing costs that keeps it from being more widespread, but I don't believe there is a definitive answer for your question. The other studios may have come to the conclusion that it is too easy to bypass using other equipment, rather than Blu-ray players or licensed software players on PC's.
These will be the last examples from me with the first release of AnyDVD HD with Cinavia removal. Should give some context as they improve the program. The two clips are from the same movie, but only dialog and a bit of background music this time.
GWTDT original dialog audio stream.mka
GWTDT Cinavia removed dialog audio stream.ac3 -
If you zoom into the waveform with something like Audacity you can see what they're doing. They're adding phase distortion. If you align the before and after samples at one point in time you'll see that one falls behind for a while then catches up again. You can see that they've removed some short sections and duplicated others. And in other places sped or slowed (and resampled) the audio. This is essentially the same thing that Cienoway did in another thread here. Looking at a spectrum view there's some extra high frequency bands in the after sample. They probably took a high frequency bandpass, doubled the rate and reduced the amplitude, then added it back into the signal.
Wow, the music in gonca's second sample sounds terrible when its processed.
Cinavia its simple invisible flag that if its detected
its stop playing file in devices like Blu-ray player or PS4?
So I can play files with Cinavia in media center PC no problem? -
Depends on what you play the files with. Arcsoft TMT 6 would detect Cinavia in all types of media files, discs or mounted ISO's. Arcsoft could integrate into Windows Media Center fairly well, and was popular while it was available. What are you using for playback? Most anything else should be ok, except other commercial players with burned discs.
Ok, here's my attempt with AnyDVD HD 7.5.9.3 and CloneBD 1.0.4.0.
Same movie, different scene, selected for the rhythmic music which distorts in the version with Cinavia removed.
Video and audio for the converted scene, but audio only for the original. The original video is just too big to upload with my snail's pace connection.
New versions 2nd test clips.7z -
Using Kodi
It's not worth it all the trouble
don't need change original sound
just get device or PC without Cinavia scan -
Guys - perhaps someone can try this way to remove Cineavia (have PS3 but to lazy for testing):
Steps:
1 Resample all audio tracks to 44.1kHz
2 Use sharp lowpass filter above 7kHz (maybe 8KHz or higher - not sure where Cinavia watermark starts)
3 Use ffdshow (or similar software) filter 'Crystality' (this is spectral band replication filter that try to create artificial high frequency content based on information from lower band) - this step may be repeat many times as you like
4 Resample audio back to native if necessary.Last edited by pandy; 13th Apr 2015 at 05:50.
Has anyone backed up a Ciniva movie with success? What do you think of it? In time it will improve but, is it acceptable now-would you buy it? These bits and pieces of sound don't move me one way or the other.
Plenty of people have used the AnyDVD HD and CloneBD combination to back up movies with Cinavia. It works. But the sound quality is just not there yet, and with this approach, it may never be comparable to the original audio stream.
Like most everyone else, I recommend using equipment that doesn't obey the Cinavia audio shutdown. There is plenty to choose from, including older Blu-ray players made prior to 2012, streaming media players and HTPC's. -
AnyDVD HD by itself does not remove Cinavia. Their solution is to use AnyDVD HD in combination with CloneBD, converting the audio to AC3 in the process. Its still not great sound.
DVDFab has introduced a new product to "remove" Cinavia, but you'll need the new Cinavia removal tool plus their Blu-ray copy section of DVDFab or the misnamed Ripper section. DVDFab likes to hit their customers with multiple charges for different modules of the software, though there is a way to buy the entire thing for an enormous price if you wish. The DVDFab removal tool substitutes the audio, and there is no way to know if it comes from other sources, or is one that they have processed themselves from the same Blu-ray movie. So far it doesn't work with DVD's that contain Cinavia, but those are few and far between.
Cinavia detection rather than removal
By BJFOW in forum AudioReplies: 9Last Post: 31st Mar 2020, 10:33 -
Cinavia removal technique?
By Kerry56 in forum Blu-ray RippingReplies: 203Last Post: 27th Mar 2015, 11:30 -
New Slysoft Update Policy:
By wtsinnc in forum DVD RippingReplies: 5Last Post: 12th May 2014, 12:53 -
Slysoft's answer
By pepegot1 in forum Authoring (Blu-ray)Replies: 6Last Post: 21st Nov 2012, 13:42 -
ANYDVDHD Slysoft in trouble?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 30th Oct 2011, 00:31
