I followed a guide where i tweaked some thing in order to send uncompressed audio to my receiver which in turn sends video to my TV and audio to Speakers. So I had laptop connected to receiver with hdmi, and then hdmi from Receiver to TV. My receiver got damaged and i temporarily need to connect laptop to TV directly. Doinf this gives me video but no audio. And i mean anywhere on Windows, not just when playing media files. I managed to get audio on files with mpc, by selecting mpc-renderer on the audio renderer settings, but cant do nothing on anywhere else.
Ideas, till i get a new receiver
Results 1 to 9 of 9
Try change the default playback device to the HDMI Output under the Sound settings in windows.
Thats what ive been doing. Theres 2 options. 2Chaneel speakers which are my laptops speakers. This option works but sound comes out of laptop and is poor. And Panasonic TV option which is where hdmi is outputing audio and video. When i go there, i can only have audio on the TV with mpc under mpc renderer and nowhere else.
What guide? and what did you tweak?
Typically you just tweak the media player. It would appear you changed something in Windows.Google is your Friend -
I really dont remember.
It was something about madVR and lav filters and tweaking things on mpc and ffdshow...
But i can get sound on my Samsung PC Monitor using it as external, i just cant get on my Panasonic TV, unless i use the mpc audio renderer -
I finally fixed this. Had to uninstall the drivers from the device shows as "Panasonic TV", i rebooted, reconnected the TV, audio drivers got reinstalled properly into the system and audio comes out from there naturally.
It seems that the AVR redirected video as passthrough and so it had the TVs name, so Panasonic TV must have somehow been setup as something of multichannel uncompressed.
->How do i figure out if my TVs speakers are Full Range speakers so i can set this option on the audio dialo menu -
Full Range = the speaker(s) play the full frequency range (ie: all of the audio).
The TV has stereo speakers, one left, one right. Full range means that Right acts as Front-Right+Surround Right+Center+LFE and respectively for left? So if Full range is not set, the surround information, center and Low frequency channels are lost?
"Full range" has nothing to do with surround sound. It simply means a single speaker plays the entire signal (ie: from the highs all the way down to the low).
>> http://en.wikipedia.org/wiki/Full-range_speaker
For stereo, that means the left speaker plays the left channel audio and the right speaker plays the right channel audio.Google is your Friend
Bitstreaming DTS-HD MA with lav filter / potplayer
By imhh1 in forum AudioReplies: 7Last Post: 3rd Oct 2020, 10:46 -
Beginner Questions. Hoping to reach a professional level as video editor
By parker7d7 in forum Newbie / General discussionsReplies: 56Last Post: 6th Jul 2015, 12:11 -
DVDFab No Sound when creating MP4. Change extension to M4V and sound works
By hackerjunk in forum DVD RippingReplies: 2Last Post: 5th Jun 2014, 16:04 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58
