hey guys
i have a movie clip i imported into vegas.
im cutting it up to pieces and so i can leave a pause in between the video animation.
for example, 00:00:05 to 00:00:10 there is no animation on the original video, but i need that period to be 20 seconds
so i cut from 00:00:05 to 00:00:10 and copy that piece and pasted 3 copies so i get the 20 seconds.
my problem is,
1 - passed the 00:00:10 the original video contains animation.
2 - i can't use copies like i did because i need to add a zoom effect to the first piece and have the subsequent copies maintain the zoom.
so my question is, i guess what's an easy way to do this,
or,
how do i force the piece i sliced to not continuing playing the original video when i extend it?
Slide the original video after 00:00:10 to the right so that it begins now at 00:00:25
The section from 00:00:05 to 00:00:25 will have the zoom effect (ie. Redo the original section from 00:00:05 - 00:00:10 , to extend it to 00:00:25 and apply the zoom effect) . If you have to, you can use a separate overlay track to "cover up" that period -
the problem is that if i extend from the 00:00:10 to 00:00:25, the original video from 00:00:10 to 00:00:25 plays, and i want that period, from 00:00:10 to 00:00:25 to freeze frame at 00:00:10 while having it be extended until 00:00:25 (on vegas timeline) while i apply the zoom.
it is like when you have an original video that finishes at 00:01:00 and you extend it in the timeline. you can de-select the loop option so the video stops playing and you see a freeze frame. i want to do that but in the middle of the original video. -
Take a still frame screenshot at 00:00:10, overlay it and stretch it out to 00:00:25. Do the zoom on the screenshot section
i couldnt find the still frame option, but i got it using the velocity.
thanks
a follow up question if i may: how do i use a preset in the pac/crop window?
ive added a new preset to the list but when selecting the preset on another video section nothing happens.
nvmd: i've managedLast edited by ricmetal; 9th Apr 2015 at 07:09.
In case anyone else needs a still in Vegas.
You can create a still in the preview window. Look around in there and you'll find it.
But don't forget to set the preview display to Full/Best.
Vegas Pro 12 - .mov files crashing comp & not playing video. Please help!
By jcarst85 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2014, 04:10 -
Cropping/Expanding Video
By elprice7345 in forum Video ConversionReplies: 22Last Post: 15th Jan 2014, 00:18 -
Expanding the whole subtitle
By Night 89 in forum SubtitleReplies: 3Last Post: 2nd Jan 2012, 20:13 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 12:35 -
Double PAL framerates, AVFS, and Vegas. Video playing back doublespeed.
By banditeer in forum EditingReplies: 13Last Post: 18th Oct 2010, 09:09
