Hello all. As my topic title says, I downloaded MassTube via the recommended VideoHelp link. I can't see it. I have my settings in Folder settings set to allow all extensions to be seen. I even turned off my AVG temporarily and re-downloaded the file. The strange thing is, When I re-download the file, I see it. When I cancel the download and go to the folder where it should be, I see nothing. Any suggestions? Thanks in advance.
* About 32 trillion $ sit, untaxed, in offshore tax havens, while 'leaders' whine that they can't afford social spending!! *
Okay. I have solved my problem. I had made a folder on my desktop called MassTube and thought I was directing my downloads into it. It turns out that a folder with that name was made automatically in my download folder. I also got thrown off when I managed to download and install it the first time, but didn't realize that the prog minimizes to the taskbar. I was clicking on the splash and seeing no activity, so I assumed that I had screwed something up by deleting something. I had a number of downloaded youtube downloaders ready to install, but had not installed them. And I wasn't sure which was Mass, so I deleted all of it. I came here because I trust VideoHelp a hell of a lot more than download.com.
All's well that ends well. Sorry to bother you. Later...
*I just tested it. I 'almost' gave a donation right from the start just because I was sure that this wasn't garbage or abusive (loaded with crap). As far as I can tell, I'm forced to give a donation. I can't get past the donation request. I just figured that it would be reasonable to try the program at least once before donating. And this is why. Any thoughts?Last edited by Arby; 7th Apr 2015 at 23:11. Reason: new development - All isn't well yet.
* About 32 trillion $ sit, untaxed, in offshore tax havens, while 'leaders' whine that they can't afford social spending!! * -
You must wait 30 seconds before you can click on the download-button. But only one time it seems.
And this a video streaming issue. MOving you.MassTube is Free. You can also upgrade to Plus edition to enable other advanced features by making a money donation. More information and instructions in "Help/Donate to Upgrade to Plus..." from application menu. -
Don't use MassTube, you have 100 other software for free
without limitation and waiting 30sec messages, forcing to donate
use 4K Video Downloader or Freemake Video Downloader -
Thanks roma. I will try those progs. The bundleware one has comments, not all positive. The other doesn't. I'll start with the bundleware one just because I find it odd that the other one doesn't have any comments attached.
What the problem?
You can download portable version without installation
just extract from ZIP and run: http://downloads.4kdownload.com/app/4kvideodownloader_3.5.zip -
Here's where I reveal my permanent newbie status. I don't know anything about 'portable'. I can guess however. That version doesn't connect to an external server? I always thought portable versions were primarily for thumb drives.
Anyway, I downloaded and carefully installed Freemake. It seems fine. It's sweet and simple.* About 32 trillion $ sit, untaxed, in offshore tax havens, while 'leaders' whine that they can't afford social spending!! *
x64 and jobs list/run invisible
By xfile in forum Video ConversionReplies: 0Last Post: 26th Nov 2014, 17:11 -
Adding invisible CGI to video to cover the human body
By masih in forum EditingReplies: 14Last Post: 2nd Oct 2014, 14:04 -
invisible watermark(sort of) without re encoding? (headers, tag,...?)
By cdtsly in forum Video ConversionReplies: 0Last Post: 24th Nov 2013, 03:46 -
When youtube video is downloaded, what quality is downloaded?
By Haopengyou in forum ComputerReplies: 3Last Post: 13th May 2012, 03:46 -
checking for invisible pdf watermarks?
By UncleBose in forum ComputerReplies: 8Last Post: 13th May 2010, 15:26
