    May 2014
    Malaysia
    Hi friends,
    I'm trying to experiment on mode decision in the TAppEncoder which is in the HEVC reference software.
    The problem: The encoder is raising the following flag as I tried to run it in visual studio:- Unhandled exception at 0x00a68b06 in TAppEncoder.exe:0xC0000005:Access violation reading location 0x00000010.
    Steps that gave the error: I modified the function void TComYuv::SubtractLuma(...). I modified it to return some variables that I want to use in making mode decision in void TEncCu::deriveTestModeAMP(.....)
    The encoder ran without problems with the changes I made in SubtractLuma(...). I think that the problem is from my codes in deriveTestModeAMP(...).
    Part of deriveTestModeAMP(...) which has my modification is shown below:
    TComYuv* pcYuvSrc1;
    TComDataCU* ptt;
    TComYuv* pcYuvSrc0;
    TComYuv* ptk;
    TComYuv* pttk;
    pcYuvSrc1=NULL;
    pcYuvSrc0=NULL;
    ptk=NULL;
    ptt=NULL;
    pttk=NULL;
    UInt uiTrUnitIdx=0;
    UInt uiPartSize=eParentPartSize;
    Pel* pSrc0 = pcYuvSrc0->getLumaAddr(uiTrUnitIdx, uiPartSize );
    Pel* pSrc1 = pcYuvSrc1->getLumaAddr(uiTrUnitIdx,uiPartSize );
    Pel* pDst =pttk->getLumaAddr(uiTrUnitIdx,uiPartSize );
    ptk->subtractLuma( pcYuvSrc0, pcYuvSrc1, uiTrUnitIdx, uiPartSize);
    if ( rpcBestCU->getPartitionSize(0) == SIZE_2NxN )
    bTestAMP_Hor = true;
    I will be grateful for any assistance.
    Apr 2015
    I am wondering how you can access pcYuvSrc1 and pcYuvSrc0 after setting them to NULL.
    May 2014
    Malaysia
    Thank you very much for pointing that out. I will factor that into the codes and check it out again.
