Results 1 to 18 of 18
    Apr 2015
    France
    Hi everybody and thank you to read my thread
    I encountered an issue about extracting IPTV url from the followinf website :
    http://www.canlitvlive.com
    For exemple, i can extract the following channel's url but it is impossible to use it on VLC or KODI :
    http://www.canlitvlive.com/izle/trt-1.html
    url is : http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=_pEsO4GmqSBI6w9gR2q3Qw&tms=1428340136
    Could you help me please ?
    Thanks a lot
  2. Originally Posted by KisSme View Post
    Thanks a lot
    hi you can use livestreamer
    the use player.swf verification so you need add this option
    --http-header "Referer=http://www.canlitvlive.com/tvplayer.swf"
    livestreamer --http-header "Referer=http://www.canlitvlive.com/tvplayer.swf"  "hls://http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=m9WTvSlr5SlozvTOUhdWZA&tms=1428348531" best
    with in red your own parameters because that expire
    [cli][info] Found matching plugin stream for URL hls://http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=m9WTvSlr5SlozvTOUhdWZA&tms=1428348531
    [cli][info] Available streams: live (worst, best)
    [cli][info] Opening stream: live (hls)
    [cli][info] Starting player: /usr/bin/vlc
  3. so for KODI you can try
    http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=m9WTvSlr5SlozvTOUhdWZA&tms=1428348531|Referer=http://www.canlitvlive.com/tvplayer.swf
    Apr 2015
    France
    Thanks !
    But, it doesn't work in KODI or VLC :'(
    I use windows and not linux
    My .m3u file is started like this :
    #EXTM3U
    #EXTINF:-1, TRT1
    http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=m9WTvSlr5SlozvTOUhdWZA&tms=1428348531|referer=http://www.canlitvlive.com/tvplayer.swf
  5. maybe it doesn't work with kodi and vlc i can't test it
    but you need update red parameters because expired
    did you tried with livestreamer
    Apr 2015
    France
    You'r right ! Now it works fine after i changed red parameters
    I dont know how to use livestreamer :'(
  7. I propose a tutorial with static Version
    1) download https://github.com/chrippa/livestreamer/releases/download/v1.12.1/livestreamer-v1.12.1-win32.zip
    2) unzip the file in C:\ (for example)
    3) so you have C:\livestreamer-v1.12.1 folder
    4) open cmd.exe (command shell)
    5) in this command shell go to C:\livestreamer-v1.12.1
    cd C:\livestreamer-v1.12.1
    6) paste the code
    livestreamer --http-header "Referer=http://www.canlitvlive.com/tvplayer.swf"  "hls://http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=9p29RTawPdnCK6SRLN5hTQ&tms=1428358700" best
    if you want record add -o option
    livestreamer --http-header "Referer=http://www.canlitvlive.com/tvplayer.swf"  "hls://http://yayin34.canlitvlive.com/trt1/live.m3u8?tkn=9p29RTawPdnCK6SRLN5hTQ&tms=1428358700" best -o trt1.ts
    Apr 2015
    Hello there,
    I'm trying to get the following live feeds to stream on xbmc/kodi. And also show me how to get the feeds or the url to steam on different devices. I did view page source but none of the url is working.
    http://www.africawebtv.com/al-jazeera-english/
    http://www.africawebtv.com/utv-ghana-online/
    http://www.africawebtv.com/vox-africa/
    http://www.africawebtv.com/kingdom-africa-tv/
    Can anyone help me. Thanks in advance.
  9. Originally Posted by djezmoney View Post
    Hello there,
    first
    rtmp://aljazeeraflashlivefs.fplive.net/aljazeeraflashlive-live/ app=aljazeeraflashlive-live swfUrlhttp://tv.filmover.com/jwp63/jwplayer.flash.swf pageUrl=http://www.africawebtv.com/al-jazeera-english live=1 playpath=aljazeera_eng_high
    second
    with kodi i don't know but works with livestreamer
    livestreamer "http://www.ustream.tv/embed/19246420?v=3&wmode=direct" best
    the two other are offline for the moment
    Apr 2015
    Biezom, Thanks for quick reply. Can you show me how to get codes. I have couple of streams i need to get. Thank you once again.
    Jan 2016
    Pakistan
    Hi,
    I am trying to use http://yayin34.canlitvlive.com/trt1/live.m3u8 on my website but i do not work and WordPress recently change the setting of JP player kindly tell me any player who support m3u8, I am using this on
    http://www.listenfmradios.com/
    http://www.africaradios.com/
  12. HI im new here
    Please help me or guide me .......
    how to extract iptv link from
    http://c247.la/live.php?ch=Geo_Super
  13. Hi I am new to the IPTV world, I have purchased a link from someone but I can not get it to work in KODI or VLC player.
    Can you please guide me on what I may be doing incorrect. Link below:
    http://portal.rapidiptv.com:8080/get.php?username=*******&password=*******&type=m3u_pl...&output=mpegts
    The url does not show the type correctly it is m3u_plus
    I have blanked the username and password out for obvious reasons.
  14. trt1 turkey mobil tv tamtvizle.com/trt-1-izle.html live stream
    Apr 2016
    canada
    hi iguys how do i renew this redcolour api token from lodi url they expire very quick
    example tkn=m9WTvSlr5SlozvTOUhdWZA&tms=1428348531
  16. The question was "How to extract IPTV link with options and use it into KODI"
    And answer is:
    You need to create .bat file (for Windows)
    Open notepad and paste this code:
    @echo off
    start livestreamer --player-external-http --player-external-http-port 58352 "hls://http://yayin34.canlitvlive.com/trt1/live.m3u8" best
    save as start.bat
    Open notepad again and paste this code:
    taskkill /f /im "livestreamer.exe"
    taskkill /f /im "cmd.exe"
    save as stop.bat
    Create playlist with notepad
    Paste this code in notepad:
    #EXTM3U
    #EXTINF:0,TRT 1
    http://127.0.0.1:58352
    save as playlist.m3u8
    RUNNING
    1. open start.bat
    2. open playlist.m3u8 (with kodi or vlc)
    3. close kodi or vlc
    4. open stop.bat
    *Replace http://yayin34.canlitvlive.com/trt1/live.m3u8 with any working (hls) stream.
    Enjoy!
    Nov 2016
    Malaysia
    Hi frend please help
    How playback m3u8 AES-128 enscrypted on xbmc or any media players
    On this link : http://playback02.aotg-video.astro.com.my/AOTGHLS/master_ARENA_02.m3u8
    Help me, tq
