rw discs dubbed on lg rh735t cannot be played on sony rdr-hdc100 dvd player. is there a way to reverse this?
I wouldn't even know where to buy -RW discs....most likely the disc needs closed or finalized or whatever term LG uses in this scenario. OR it's an older Sony that accepts almost nothing "burned".
this link here - http://www.sony.com.au/product/rdr-hdc100 says the player
will playback -R media. try finalizing the disc. also the brand of rewritable disc can play a factor
in weather the disc will play in your player. also the lazer might be dying thus your player
might have a hard time reading discs or need to be cleaned. -
Thank you all who replied. It would seem after reading replies from others that I should change from Phillips, TDK -R/RW to verbatim +R/RW. It would appear that LG 735T will not finalize R/RW discs, -+R only.
Need to decode Sony DVD to play all regions
By Rhonda in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Apr 2011, 23:36 -
HELP Sony HT Cant play athoured dvd
By zeh.esn in forum Authoring (DVD)Replies: 8Last Post: 19th Apr 2011, 14:48 -
What is the best format a dvd needs to have to play on my Sony
By frenchman96 in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2011, 20:09 -
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Sony VHS to DVD does not play
By shanimaz in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2010, 10:17
