I am recording audio to a GoPro Hero 4 Silver via my Midas mixing console. Audio sounds great on all devices except any mobile device. IE: Iphone 5S. I even uploaded the videos to you tube. Again they look and sound great on all devices, except the Iphone. Please help!
Results 1 to 10 of 10
Sounds like the audio is underwater. Only on iphone, android, samsung. Has something to do with stereo input to the gopro.
What audio codec did you use, what bitrate and what sampling frequency?
I tired multiple options, including seperating the audio from the video, importing into Pro tools, then bouncing to disk as an mp3. Then import into Imovie as I have been doing previous to this camera. Exporting from Imovie into a Mp4 file. Then on to You Tube ect. Just like I always do. Nothing has worked except recording mono into the gopro. Then all the other media players have only one side.
The GoPro Hero 4 Silver records at 48kHz sampling rate, AAC compression, mono.
Stereo is only available (input) via the 3.5mm adapter. -
I guess you missed the original post. I am sending an aux mix from the midas console into the gopro via the stereo input cable. I belive Gopro as overlooked the stereo issue when playing back on a mobile device that has a mono speaker.
Then we both agree that the problem probably has something to do with "mono vs. stereo" somehow. I don't have a GoPro so I cannot attempt to replicate the problem/scenario. Only one person involved in this thread has access to a GoPro Hero 4 Silver's files. I do know however that going from an audio file that is 48kHz straight to an MP3 file for listening produces some funky sounding results.....AND there is a proper way and a wrong way to go from 48 to 44.1 - I've just forgotten the exact terminology(IE Playback Rate or Resample in GoldWave).
Cool. Thank you. That last bit about 48 to 44.1 has given me an idea. I do have Pro Tools 11. Do you believe that the bit rate is 48KHz in the stereo mode? Or is the bitrate the same when recording in mono? I have to check, but I thought I changed the bit rate in protools when I converted the audio file to mp3. I'll check on that again.
GoPro Hero (entry level) What format?
By micklos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 10th Apr 2015, 02:54 -
audio AGC levels + limiter in gopro files
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 31st Oct 2014, 14:44 -
New GoPro 4 Silver
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Oct 2014, 12:31 -
problems viewing videos they zoom way in
By mschafer in forum ComputerReplies: 1Last Post: 20th Apr 2013, 13:50 -
Converting IFO file DVDs to M4v for Iphone viewing
By anotherhappyday1 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2012, 14:41
