Results 1 to 9 of 9
    Aug 2014
    Switzerland
    Hi,
    I have 2 languages in my vob file and I would like to erase one of them
    how to proceed pls ?
    p.s. I am using vobedit (never used it before)
    regards
  2. Demux the DVD (if it's a real DVD) with PGCDemux. Reauthor with Muxman, leaving out the language you don't want. Add it back to the original DVD using PGCEdit.
    If all you really have is a VOB (why?), then demux (DGIndex is one way (File->Save Project and Demux Video)). Remux with Muxman to make a DVD or Imago MPEG-Muxer to make an MPG, leaving out the language you don't want.
    Aug 2014
    Switzerland
    hi
    I have a vob file (not dvd, I already excracted files form dvd but forget to take off languages there)
    so, I have ''vob edit'' and a vob file
    how to take off langage with vobedit pls ?
    I dont know what is demux, remux, mux, etc...
    I only need a simple way to do
  4. Vobedit has a 'Demux' button in the bottom center to separate out the audio and video files. And it has a Remux M2V button in the Edit area. This is nothing you couldn't have figured out for yourself.
    It's quite old and the programs I mentioned will do these things quite easily.
    Aug 2014
    Switzerland
    I see (I have 2 languages in my video: french and japanese)
    I tried to demux with DGindex as you said but my video have no sound now
    and it create a mp3 sound file a part, only with the french language
    how to add sound again to my video, but the right sound (japanese) ?
  6. Originally Posted by erzane View Post
    Did you not understand what I wrote?
    ...demux (DGIndex is one way (File->Save Project and Demux Video)). Remux with Muxman to make a DVD or Imago MPEG-Muxer to make an MPG, leaving out the language you don't want.
    Aug 2014
    Switzerland
    **** you
  8. You should have deselected the language you don't need when you ripped the DVD. You can still easily take care of it with DVDshrink/Recode, it just means adding one extra step to the process.
  9. Originally Posted by nic2k4 View Post
    He doesn't have the DVD, just a VOB. He has to demux first. But, as you say, it's still quite easy, although it may be beyond this person's limited abilities.
