Hello,
I would like to take out certain segments from a vhs capture that have dropout and replace them with recaptured, clean video from a different copy of the same tape. How can I line up the segments to ensure that the segments are in sync and fit together correctly? Looking for a non-Avisynth solution if possible.
Do you want to spend money on a video editing program? I have been using Pinnacle Studio over the last 10 years or so with very little problems.
I am using version 18 now and it has the tools to do what ever you need with a lot of professional other tools as well. But be fore warned, you will need to spend some time in learning how to use the program. Not easy and very complicated but you get some really good results. And last, never use the program to burn your project to a cd or dvd. It seem to have some issues in that department. I use TMPGEnc Authoring 4 for that. It works for me.If it feels good, do it.
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Olympics Video - Need Help Joining Segments.
By chargedbird in forum Newbie / General discussionsReplies: 8Last Post: 10th Feb 2014, 17:15 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Tweaking VHS captures
By Cherbette in forum RestorationReplies: 165Last Post: 11th Oct 2011, 10:37 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32
