I have two Panasonic DMR E100s and a Panasonic DMR E700BD - both the DMR E100s are DVD HDD recorders. The DMR E700BD is a BLU RAY HDD and DVD HDD Recorder which was purchased in Japan some eight years ago.
During the past few months there has been a problem with the discs not being released from the tray for the DMR E100s - it would not open, or I get the fatal "SELF-CHECK" problem. However, on several occasions I have been able to get the disc out using the instructions posted elsewhere on this Forum for the self check problem.
I had the same problem with the DMR E700BD - I could not get the disc out so used the solutions for the DMR E100 - and it worked, I got the disc out - BUT NOW - I get the message - "LOCK" - and I can do nothing to get the recorder back to it's normal operating system. It will power up and shut down but nothing more. It appears as though the recorder is "locked" for all functions other than these two.
It's a very good BLU RAY/DVD recorder and would hate to just use it for a door stop - besides - it was not "cheap" originally - somewhere in the $1,400.00 price range if I remember correctly.
Is there a known - "UNLOCK" - sequence for ANY Panasonic recorder that may work in this instance? I can use all the help that anyone may have. I thank in all in advance.
Maybe this thread will help?
http://www.avsforum.com/forum/106-dvd-recorders-standard-def/1142245-panasonic-e80h-sh...-ram-disc.html
Disc tray problems on Panasonic DMR EH-67 DVD Recorder
By Terje1968 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jan 2013, 13:38 -
Panasonic DMR-E30 Unfinished Disc Help Needed
By inabind in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th Sep 2012, 16:09 -
Panasonic DMR ES35V - False 'disc loaded' reading
By buck1107 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 17th Jul 2012, 12:58 -
Panasonic DMR EZ28 Won't Eject Disc, Keeps Turning On & Off
By Garyrajsich in forum DVD & Blu-ray RecordersReplies: 3Last Post: 11th Jun 2011, 18:19 -
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 15:39
