Hi.
It is possible to have 2 previews of tracks without any changing resolution ?
Results 1 to 9 of 9
http://avisynth.org.ru/docs/english/corefilters/stack.htm — Is this what you want
If you need two players running at the same time I wrote a little command line program that will search for certain text in the available windows title bars, if it finds the text it will switch focus to that window then send a [SPACE] keystroke (a pretty much universal PLAY command) and move onto the next window. I managed to get iTunes and VLC in sync with it, although I'd need to rewrite it a tad to search for arbitrary strings (they're currently hardcoded.)
There's probably better programs out there to do the job though. -
I need to do this in a video editor,because i want to slow down/speed up video.
Such as Sony Vegas,Premiere Pro,PowerDirector...
Anyway,thanks for reply. -
Yeah, what you are wanting is the equivalent of a poor man's version of multicam editing.
+1 smrpix's suggestion. Side-by-side mid-wipe (aka split screen), PIP, 1/2 transparent overlay, alternate-frame cycling...
Can be done natively in most of the better editors, or added to any editor that accepts AVISynth scripts as "sources".
Scott -
smrpix - Yes! I tried this,but i dont know how to set scale precisely,and i dont want repositing it,just a filter to PowerDirector to Splitscreen.
If you want PowerDirector to write a preset -- tell them. You asked about other software as well and they each work slightly differently -- none of this is hard to learn.
VSDC video editor shows image on preview, but when I export the video
By elisape in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2016, 04:51 -
Mkvmerge - no video after muxing several audio tracks and bd remux video
By portgas in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2014, 08:24 -
video preview
By shawnmcm in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2012, 23:56 -
No Video Preview
By dfehr33 in forum EditingReplies: 1Last Post: 8th Mar 2011, 23:43 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56
