Hi!
Over the last few days, I've collected some 3D DCP's. for those of you who don't know the specs of these kind of files, here they are:
as you can see, the video has 48FPS and each eye gets 24FPS, so this is frame interleaved 3D (I think that's how it's called). Does anyone know a way to convert this to 1080p bluray/MVC 3D with same specs as an average 3D bluray?Video
Formaat : JPEG 2000
Format_Settings_Wrapping : Frame
Duur : 2mn 16s
Bitrate : 156 Mbps
Breedte : 1 998 pixels
Hoogte : 1 080 pixels
Beeldverhouding : 1,85:1
Framerate : 48,000 fps
Originele framerate : 24,000 fps
ColorSpace : RGB
ChromaSubsampling : 4:4:4
BitDepth/String : 12 bits
Scansoort : Progressief
Bits/(Pixel*Frame) : 1.510
Stroomgrootte : 1,24 GiB (50%)
Titel : Picture Track
I now that the best way to get from JPEG2000 to a playable video format is to encode it to ProRes, but what do I have to do after that?
Thanx!
Arthurm
(SFMBE)
Hmmm... maybe I should ask this question diffently.
How can I get Frame sequential 3D to 2 different video stream? and after that, how can I encode it to MVC? thanx!Last edited by arthurm; 5th Apr 2015 at 13:59.
I would use ffmpeg & AVISynth & FRIM to:
Demux the MXF wrapper to raw picture sequence
Separate the odd & even pix and re-label when done (001-L.j2k, 001-R.j2k, 002-L.j2k, 002-R.j2k, etc), possibly putting temporarily into separate folders. I'd use a batch renamer, or similar filemanager tool for this part.
Decode+frameserve to Frim encoder (do NOT use intermediate ProRes).
Then use a BD3D authoring app (tsmuxer, Cyberlink PD/PP, Sony Vegas Pro, Jive3D, DoStudio, BluPrint, Scenarist).
Scott -
hi, thanx for the answer!
Do you think you can give me some tips for creating the lines (or maybe even the lines itself)? I know how to use ffmpeg (but not how to write lines), but don't know anything about FRIM, only what is does. So I have to use RAW footage for FRIM. Does that mean that I can select resolution, bitrate etc. and can I encode a 1:2,40 video to 16:9 in FRIM?
ArthurmLast edited by arthurm; 7th Apr 2015 at 17:21.
okay,
so I managed to get all the frames to TIF format using this line in FFmpeg:
Now I have 6559 files with the name image000001, image00000, image000003 etc etc...ffmpeg -r 48 -i INPUT.mxf OUTPUT\image%06d.tif
I have downloaded and installed Bulk Rename Utility and I'm trying to get 001-L.tif, 001-R.tif, 002-L.tif, 002-R.tif etc.
Does anyone know how to do this?
After solving this problem I'm probably going to need some help with the FRIM encoder.
I'm sorry that this thread/question is such a "big" one, and not just one part of the process, but I think it is also usefull for other people to make 3D DCP's playable.
BTW: The Even numbers are for the left eye and the odd numbers for the right eye.
ArthurmLast edited by arthurm; 7th Apr 2015 at 17:49. Reason: BTW added
Okay. I Finally got all the images in seperate folders, one for the left eye and one for the right. The problem is that all the images are TIFF format, with RGB colorspace. For FRIM I need a YUV file for both eyes to get a MVC stream. I tried this line:
But that doesn't seem so be working at all. I don't get an error or something, but it doesn't process anything. I read all the guides regarding FRIM, and I don't think that will be a problem after I have my YUV files.ffmpeg -i INPUT\image%06d.tif -pix_fmt yuv420p -r 24.000 -y output.yuv
Does anyone know how to get from a (RGB) TIFF image sequence to a 24FPS YUV file?
Arthurm
Help converting MVC to SBS
By WOODY3d in forum Video ConversionReplies: 1Last Post: 23rd Nov 2014, 00:30 -
Re:Video Streaming in mvc site
By premkumar in forum Video Streaming DownloadingReplies: 2Last Post: 17th Oct 2014, 04:43 -
Avi to Dcp
By Lucid_Dream in forum Video ConversionReplies: 4Last Post: 3rd Apr 2013, 06:10 -
See a lot on MVC, so.... how can I convert to it?
By Shilar in forum Video ConversionReplies: 7Last Post: 11th Mar 2013, 02:58 -
regarding DCP
By sergeiEV in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2012, 02:52
