Guys, back in my days (around 2001-3, when I encoded a lot) was the best Xvid with some custom settings (mpeg matrice, for best sharpness and so on)...
What novadays to use, with AT LEAST two passes, to reencode movie rip to 1280 pixels horizontal size? Please suggest... at best not some standalone programs, but codecs I can use on VirtualDub... or something else.
I got a good results with Windows Media Encoder and 4000 Kbps bitrate for this resolution, BUT this good program does not work on Windows 7 machine with i5 CPU, witch I need, because on old P4 box this encode could take ages (or at least I fear that it will, since the source file is 16G in size) ...
Suggestions?
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config
What do you mean "rip to pixels". That doesn't make any sense.
Use anything that can encode using x264 encoder and for 1280x720 , use 1pass (you do not need 2pass) CRF 18 (that means quallity choice), rest leave defaults, or you can set preset slow (better compressibility where bitrate goes down tiny bit) but then better set reference frames as 4 (higher numbers might trouble hardware players) , and even with tune film (leaves a little bit more noise after encoding, also tiny bit less postoperative or banding then).
You get about those desired 4000kbps as average - depends on movie, for those settings above
Should I rip standard def DVD to 1280 x 720?
By zBernie in forum Newbie / General discussionsReplies: 9Last Post: 17th Jun 2014, 11:49 -
Downsizing help using mod16
By kkiller23 in forum Blu-ray RippingReplies: 5Last Post: 15th Jul 2012, 02:01 -
DVD screen to 1280 * 720 (Handbrake)
By Hydra in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2012, 04:13 -
Selecting resolution 1280 *694
By kurian in forum Video ConversionReplies: 8Last Post: 14th Feb 2011, 12:07 -
keep 720px 1280
By wthldh in forum Authoring (DVD)Replies: 9Last Post: 12th Apr 2010, 21:12
