I have a multilanguage dvd which includes hungarian language audio.
There are also subtitles - these are closed captioned.
I have used handbrake to convert to mp4 with hungarian audio, and would like to have the hungarian subtitles showing permanently (burned in)
However handbrake; although it will provide the dvd with hungarian audio will not produce for me an mp4 file that shows the closed captions . I did select the "close captions" option - hungarian - in the subtitles tab, and ticked "burned in" box, but when I viewed the resultant mp4 file, no subtiles were showing.
Please can anyone advise.
Yours with thanks
Ian
ian c
Did you get any switchable subtitles? Check with vlc media player under subtitle.
You could also try vidcoder.
Or extract the closed captions with ccextractor as srt subs and add the srt in vidcoder. -
Handbrake can only use SRT subtitles and N. American closed captions, as far as I know. Handbrake's closed captions option works with N. American closed captions, which are stored in the GOP user data for the DVDs MPEG-2 video.
DVDs made for other parts of the world use something else instead of this kind of closed captioning, selectable subtitles for the deaf and hard of hearing. These are in DVD subpicture (SUP) format. If that is what your DVD has, you have more work to do.
SRT subtitles are sometimes available from various websites. The other option is to use Subtitle Edit's optical character recognition on the DVD subtitles with a Hungarian Tesseract OCR Dictionary. https://code.google.com/p/tesseract-ocr/downloads/detail?name=hun.traineddata.gz Unpack it to the "Tesseract\tessdata" sub-folder. I have never tried this option. I only know it exists. -
And you'll need a Hungarian dictionary for Subtitle Edit as well (Spell check -> get dictionary)
And BTW Subtitle Edit now has the option of downloading the tesseract file from the OCR window. Also note that the placement depents on wehther you use a portable version or not.Last edited by videobruger; 4th Apr 2015 at 17:03.
Embed Closed Captions in MP4
By video2me in forum Video ConversionReplies: 4Last Post: 11th Feb 2020, 17:55 -
DVD to MP4 with Closed Captions
By KarlLichtmann in forum Newbie / General discussionsReplies: 16Last Post: 25th Aug 2014, 03:49 -
Removing closed captions (subtitles)
By CAS99 in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2013, 06:46 -
Convert Closed Captions to Subtiltle on DVD-Keep Original Menus
By emsdallas in forum SubtitleReplies: 1Last Post: 2nd Oct 2010, 18:42 -
Ripped DVD - Search Through Subtitles / Closed Captions?
By foochuck in forum DVD RippingReplies: 2Last Post: 19th Jun 2010, 11:59
