I'm finally upgrading from xp 32bit to win7 64bit and hoping i can get megui running again a bit quicker than i managed all those years ago; the steps i took are unfortunately long forgotten.
I've downloaded
ffdshow
and ensured all the relevant codecs have the libavcodec option enabled in the video and audio configuration windows.
followed by
ffmpegsource_20071006
ffmpeg-2.5.4.tar
ffmpeg-20150402-git-d759844-win64-shared
And because there's never a clear indication of what to do with them, i've installed every dll in each and every directory i can think of including megui tools, avisynyth2.5 plugins, windows\system32.
If i try to use directshowsource as in this script:
DirectShowSource("G:\FilmTitle.2013.1080p.DTS.mkv" , fps=23.976, convertfps=true)
it just tells me that the video and audio sources are not supported.
If I try to use ffmpegsource as in this script:
FFmpegSource("G:\FilmTitle.1080p.DTS.mkv")
It hangs for a long time and then opens very blocky video. It also leaves a file called FilmTitle.1080p.DTS.mkv.ffv0cache, which it never used to do before.
Can someone help please?
Thanks.
Results 1 to 11 of 11
ffmpegsource is very old version (probably broken), about 7-8 years old
ffmpegsource2 (ffms2) is the newer version. You can download it separately, but I think the newer megui versions have it included
If you still want to get directshowsource working, try installing lav filters. You might have to fiddle with preferred codec tweaker to get lav working -
Appreciate the reply - but can you be a bit more precise please?
Do I actually need ffms2 if i have the latest megui?
If so, what do i do with all the dlls when i download them? If not, why don't my scripts work?
What do i do with all the lav dlls and ax filters? where do i put them? -
I think everything should be included in the modern megui versions . It can create the script for you
But if you want manual steps :
Download ffms2, and unzip it.
https://github.com/FFMS/ffms2/releases
If you place the contents in your avisynth/plugins folder, ffms2.dll will autoload, otherwise load it manually in the script with LoadPlugin for the avisynth 2.58 version, LoadCPlugin for the 2.6 version
The syntax has changed, it's FFVideoSource() now, not FFMpegSource()
LoadPlugin("PATH\ffms2.dll")
FFVideoSource("G:\FilmTitle.1080p.DTS.mkv")
That's just for video, audio is loaded with FFAudioSource
aud = FFAudioSource("G:\FilmTitle.1080p.DTS.mkv")
vid = FFVideoSource("G:\FilmTitle.1080p.DTS.mkv")
AudioDub(vid,aud)
There is an ffms2.avsi in the zip folder which is a "helper" fuction, FFMpegSource2(). It basically combines the above FFAudioSource and FFVideoSource with audiodub. atrack =-1 for the 1st audio track
FFMpegSource2("G:\FilmTitle.1080p.DTS.mkv", atrack=-1) -
If it's FFMS2 2.6.x , you need to use LoadCPlugin, not LoadPlugin. Cplugin won't autoload, unless you put an .avsi in there with a LoadCPlugin statement
LoadCPlugin("PATH\ffms2.dll")
FFVideoSource("G:\FilmTitle.1080p.DTS.mkv") -
I think i had the x64 file in avisynth. With the other ffms.dll it takes minutes to open, but it does in the end. It only used to take a few seconds. Any idea why? Is there a directshow method?
Everything should be x86 for avisynth - the x64 branch is unstable, and doesn't have as many plugins/filters available
It is supposed to "hang" for a minute or so, because it's indexing the file. The larger and longer the file, the longer it will take to index
You can try it on another, smaller MKV to see if it works at all first -
Well, it seems to work and thanks a lot for that, but it seems a step back - we're talking 90secs with a big film including the audio. Is there no way i can return to the old system that worked so well on xp with directshowsource or FFMpegsource? i.e no indexing?
The old ffmpegsource took just as long (it indexed it too)
You can use directshowsource, but you have to configure your system directshow filters to work, and you are prone to directshow issues (frame accuracy problems, especially with temporal filters, possible directshow configuration/filter issues) -
Ok that's enough for one day, my brain is starting to ache. I'm sure i'll be back to pick yours again soon
Thanks again and have a good bank holiday.
Problems opening an MKV file.
By jade88 in forum Software PlayingReplies: 12Last Post: 2nd Apr 2014, 14:49 -
Mkv to avi with megui
By ConanEdogawa in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2013, 03:24 -
MKV to AVI using MeGUI
By socrates in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2012, 04:39 -
Editing Opening and Ending Credits in an MKV
By TheLaserdisc in forum EditingReplies: 3Last Post: 8th Jul 2011, 02:55 -
a problem opening MKV or MP4 files
By gis4ever in forum Video ConversionReplies: 10Last Post: 7th Jul 2010, 13:39
