Hi all,
I'm trying to encode some videos to xvid with avidemux by following the suggestions in this post. Unfortunately, the avidemux interface has changed quite a bit since this post was written.
There's now a "macroblock decision" dropdown with the following options: None, DCT, Qpel16, Qpel8 and Square - with Qpel8 being the default settings. The above post (as well as some other threads I've read) suggest that Qpel should be avoided when aiming for compatibility with divx certified players.
Since the Qpel option can't be simply unchecked anymore what should be selected instead? Any help appreciated.
Results 1 to 1 of 1
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 05:23 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27
