I haven't used my 1980's Sanyo VM-RS2 8 MM camcorder for some time. Recently I hooked it up to my Sony flatscreen via the RCA video/audio cords.(composite in)
and come to find out that it only play thru to the tv in B&W. I changed the cords. Still the same result. Also tried a 1980's older tv with the same B&W result.
Any suggestions as to why this is so?
Rob
Are both TV and camcorder using the same format, e.g. PAL or NTSC?
The manual for the Sanyo camcorder says:Television system:NTSC EIA
The manual for my Sharp TV says: TV Standard ATSC/NTSC System. -
go into the camera's setting and see if there is some kind "DIGI- EFFECT" setting
which allows recording in different effects/colors like black&white ect. -
There are no settings that allow different record types ie B&W vs. color etc.
Somewhere I read that the camcorder head may be dirty. Wonder if this is worth pursuing?
The B&W is very clear. -
double check your connection, if you are using the yellow - red - white cables, the yellow cable goes into the yellow video in connector
and the red goes into the red audio in connector and the white goes into the white audio in connector. -
try hooking the camcorder to a different / friends tv to see if it is the camera or your tv.
Turns black and white
By dadihawks in forum Newbie / General discussionsReplies: 1Last Post: 1st Oct 2011, 05:59 -
Sanyo VPC-CG20 HD Playback Issues - Wrong codec / player??
By Houli in forum Software PlayingReplies: 2Last Post: 2nd Aug 2011, 16:40 -
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 08:39 -
black and white
By foofie131 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 21:15 -
Have a Sanyo DWM 390 dvd player that shows only black and white
By blackkat in forum DVD & Blu-ray PlayersReplies: 21Last Post: 28th Jan 2011, 19:24
