Hello,
i would like to ask if bit depth (bits per sample) and sampling rate are used (for example as ffmpeg arguments) only for uncompressed audio and bit rate is used for compressed ?
For example bit depth,sampling rate is used only for wav,au and bitrate for mp3,flac,aac,alac and so on.
Results 1 to 10 of 10
Not true all audio compressed or not must have an implicit bit depth and bitrate.
When it comes to compressed lossy audio, it has bitrate but not necessary bitdepth. For example, MP3, Vorbis or AAC don't have bitdepth. Decoder can decode it as 16-bit, 24-bit or 32-bit, its up to decoder.
WAV or FLAC (lossless) codecs have native bitdepth as audio is stored as 8, 16, 24 or 32 bits per sample. In order to achive lossless decompression decoder must decode it as 8, 16, 24 or 32-bit audio. Decoding in any other bitdepth means that decoder is broken.
Most lossy codecs do not have native or fixed bitdepth. Decoder will decode these formats using one of the standard bitdephts for PCM (8,16,24 or 32 bits per sample) and every value is valid. -
I accept that I should wrote PCM instead of WAV as WAV is container that usually holds PCM but it can hold MP3, AC3 or some other format.
I also wrote that PCM or FLAC support different bitdepths, as you confirmed. -
Yes.
On re-reading your comments I now understand what you mean.
You are right in that a lossy compressed format does not have a fixed bit depth and neither a fixed sample rate, it totally depends on the compression method. However there is an implicit bit depth which in case of lossy compression may not be an integer value! -
Thanks for the answers.
I am asking because in the ebook "FFMPEG Basics" it says that :
Code:File size calculation The final file size of encoded output is the sum of audio and video stream sizes. The equation for video stream size in bytes is (the division by 8 is for the conversion from bits to bytes): video_size = video_bitrate * time_in_seconds / 8 If audio is uncompressed, its size is calculated by the equation: audio_size = sampling_rate * bit_depth * channels * time_in_seconds / 8 To calculate the file size of a compressed audio stream, we need to know its bitrate and the equation is audio_size = bitrate * time_in_seconds / 8 For example to calculate the final size of 10-minutes video clip with the 1500 kbits/s video bit rate and 128 kbits/s audio bitrate, we can use the equations: file_size = video_size + audio_size
AVSToDVD fails to author DVD from BluRay due to zero bit rate audio track?
By cbrooksathome in forum Authoring (DVD)Replies: 11Last Post: 29th May 2014, 15:06 -
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 21:56 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 21:00 -
How to reduce Audio Bit Rate
By mad_mackem in forum Video ConversionReplies: 6Last Post: 28th Dec 2011, 09:30 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17
