Hi All,
I am trying to download video embedded in this URL:
http://www.zeemarathi.com/shows/ka-re-durava/video/ka-re-durava-episode-195-march-31-2...l-episode.html
I tried using both KSV adobe HDS downloader and livestreamer. I am not able to find the right command.
Pl. help to find the right command.
Note: Thanks to biezom and ponens but I still was unable to download.
Thanks ponens.
Here is what you suggested me to try.
https://forum.videohelp.com/threads/369668-Helpful-solution-to-download-this-video-It-s...=1#post2383206.
I tried following:
I get the following error.Code:livestreamer hds://http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4" best -o Ka_Re_Durava_Episode_195.ts
C:\PHP>livestreamer hds://http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4" best -o Ka_Re_Durava_Episode_195.ts
[cli][info] Found matching plugin stream for URL hds://http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4 best -o Ka_Re_Durava_Episode_195.ts
error: Unable to open URL: http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032...032015_864.mp4 (403 Client Error: Forbidden)
Could this be an Authentication error? -
That's incorrect. Don't use livestreamer with the direct http mp4 url. Also, you need to use the entire url, like this...
Just paste it into the address bar of the browser or downloader of your choice. Change _100.mp4 to _864.mp4 for highest quality, but keep the rest the same.Code:http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_100.mp4?hdnea=st=1428012867~exp=1428014367~acl=%2F%2A~hmac=1542223765f5f527476746dc80f40d120c74b6272e0358844da97b41669bf1e4
Don't use the above example, get a fresh copy of the url from the source page yourself, everything between the quotes in the source, like the example above.Last edited by ponens; 2nd Apr 2015 at 18:37.
Anonymous84347344Guest
Supported streaming protocols:
Code:Adobe HTTP Dynamic Streaming hds:// Akamai HD Adaptive Streaming akamaihd:// Apple HTTP Live Streaming hls:// hlsvariant:// Real Time Messaging Protocol rtmp:// rtmpe:// rtmps:// rtmpt:// rtmpte:// Progressive HTTP, HTTPS, etc httpstream://
Code:http://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4?hdnea=st=1428146678~exp=1428148178~acl=%2F%2A~hmac=15625aa5be9b439a2a2de84db784648326c9ec41aa179c29b11a0162f93eee51
Code:livestreamer "httpstream://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4?hdnea=st=1428146678~exp=1428148178~acl=%2F%2A~hmac=15625aa5be9b439a2a2de84db784648326c9ec41aa179c29b11a0162f93eee51" best -o 01.mp4
Code:[cli][info] Found matching plugin stream for URL httpstream://pmd.dittotv1.com.edgesuite.net/draco/shows/Zee_Marathi/Ka_Re_Durava/March/31032015/Ka_Re_Durava_Episode_31032015_864.mp4?hdnea=st=1428146678~exp=1428148178~acl=%2F%2A~hmac=15625aa5be9b439a2a2de84db784648326c9ec41aa179c29b11a0162f93eee51 [cli][info] Available streams: live (worst, best) [cli][info] Opening stream: live (http)
Thanks so much, nullacht.
I stand by the "That's incorrect" portion of my statement, since the statement is referring to Melbtiger's command line usage...
livestreamer hds://....[progressive HTTP url]
Surely, nullacht, you would agree that this is an incorrect usage?
I could also stand by the "Don't use livestreamer with the direct http mp4 url" portion of my statement because this statement is clearly not in the declarative mood but rather the imperative mood. The statement is a recommendation, not a statement of fact. For simplicity's sake, I think it is a good recommendation.
If I were to revise the statement from an imperative mood to a declarative mood, I would have probably said "You don't need to use livestreamer with the direct http mp4 url". -
Thanks ponen and nullacht.
ponen, i did rightly understood the meaning of "incorrect" and I am sure nullacht as well now. Your solution did worked for me and it was easy for a novice person like me. Thx again.
nullacht, thanks to you for explaining in detail & yes the livestreamer command did worked for me. I want to know more about these protocols now and also how to use them.
To All, While this is my first adventure into these streaming protocols, I just want to know few basic things about them.
1. What factor decides which protocol needs to be used? In the case above it was livestreamer, but why cannot we use HDS? (does m3u8, f4m....play any role in this?) Is there any simple basic rule to start with in order to differentiate these protocols just by looking at the video source url or anything else in source?
Download HLS video using ffmpeg
By aliv in forum Video Streaming DownloadingReplies: 3Last Post: 11th Jun 2014, 19:52 -
iOS, Android, Desktop -- Use Adobe AIR - HLS, HDS, or Transmux?
By quantass in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Feb 2014, 12:37 -
HLS, HDS, DASH, RTMPT -- Adobe Air or Media Server or Other??
By quantass in forum Video Streaming DownloadingReplies: 2Last Post: 10th Feb 2014, 18:08 -
Download from Apple HLS Streaming
By adi10289 in forum Video Streaming DownloadingReplies: 31Last Post: 11th Jan 2014, 06:54 -
TWO external HDs not spinning up, what gives???
By sdsumike619 in forum ComputerReplies: 11Last Post: 9th Dec 2012, 12:04
