I am in the process of putting some SD footage on Blu-rays. When i import the footage, the default Kbps for a new track is 3000kbs. I know higher bitrates usually means better quality, but at a certain point, it stops making a difference. Does anyone have any ideas about what's a proper bitrate for SD footage when having TMPGENC author to blu-ray?
If the video is interlaced, MPEG2 in TMPGenc Author will give cleaner interlace results than x264, but it'syour choice. Either way, for SD, getting above 8000 kbps starts giving diminisihing returns, but I regualarly use 10000 for a lot of motion. That's VBR, you can stick with 15000 max and around 8000-10000 target.
The maximum bitrates, GOP sizes, etc., for SD BluRay in h264/AVC/MPEG are in tables on this page: http://forum.doom9.org/showthread.php?t=154533Last edited by LMotlow; 1st Apr 2015 at 13:54.
- My sister Ann's brother
AVCHD 1080/60i 1080p bit rates
By iL1fe in forum Newbie / General discussionsReplies: 15Last Post: 20th May 2014, 14:16 -
Bit Rates etc....
By Deadmoney in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2011, 22:30 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
1920x1080 / 59.94i Footage From High-Def Camcorder - TMPGENC Auth. Works 4
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Oct 2010, 12:31 -
Adobe Media Encoder h.264 at low bit rates.
By x2x3x2 in forum EditingReplies: 5Last Post: 21st Jul 2010, 18:00
