8mm projector ?? for online inquiries! 3-30-15
Hello!
I am trying to dump both 8mm & super 8 to my computer via a telesync box
and a sony hi8 camcorder with a capture unit (aren't we allI knew I would
run into a frame rate problem before I started, so my projector does not have
any type of speed control whatsoever. I am under the assumption after
reading various posts, that most film in this category run on average @ 18fps,
yet camcorder and/or capture unit grabs it at 24fps? I have seen other
brands online that have either a switch to toggle between 18-24 or a variable
speed control, but I haven't seen what that control tops out at. One was 14-
22fps, which is close, but it makes sense ( I could be wrong ) that if it was 24
(or 23.97fps) that would eliminate the "strobe" or "flicker" effect. I have/use
anything from a simple Nero program, to Vegas &/or Premiere to edit in post,
but with what I have now, it looks better just playing it on the projection
screen.
Do you have any suggestions or products that can fill this request without
spending $1500-$3000 on a machine that has a camera and dvd burner
already built in?
I've seen everything from shooting it on a screen/wall/piece of paper to
making a lens out of a webcam (which looks very in depth) and was just
wanting to get thoughts on both process and products.
Thank you in advance for your assistance, and moreso for such an
informatiable site!
Sincerely,
Dave
Results 1 to 1 of 1
Video edited out of synch but then fooled it to synch perfectly; How come?
By johnharlin in forum EditingReplies: 1Last Post: 22nd Sep 2012, 07:24 -
Cuttermaran 1.70 synch issue
By cjbrown80 in forum EditingReplies: 5Last Post: 30th Aug 2011, 11:16 -
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 07:27 -
Need some help with a synch problem
By kotyczka in forum AudioReplies: 3Last Post: 10th Jul 2011, 07:26 -
audio not in synch
By ak.premkumar in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2010, 10:51
